[Geoserver-users] Points of LinearRing do not form a closed linestring
Hello,
I'm trying to send a GetFeature (post) request using a Filter. But I keep
getting the above error and I have no clue about the cause of the issue
(because it's closed). If I create a LinearRing using JTS and the same
coordinates the Geometry is created without any errors.
The request I try to send:
<wfs:GetFeature service="WFS" version="1.1.0"
  xmlns:wfs="http://www.opengis.net/wfs&quot;
  xmlns:ogc="http://www.opengis.net/ogc&quot;
  xmlns:gml="http://www.opengis.net/gml&quot;
  xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;
  xsi:schemaLocation="http://www.opengis.net/wfs
                      http://schemas.opengis.net/wfs/1.1.0/wfs.xsd&quot;&gt;
  <wfs:Query typeName="feature:ViewRWZI" xmlns:feature="JAGIS">
    <ogc:Filter xmlns:ogc="http://www.opengis.net/ogc&quot;&gt;
      <ogc:And>
        <ogc:BBOX>
          <ogc:PropertyName>GeoNode</ogc:PropertyName>
          <gml:Envelope srsName="http://www.opengis.net/gml/srs/epsg.xml#31370&quot;&gt;
            <gml:lowerCorner>-284279.94433594 -12078.599121097</gml:lowerCorner>
            <gml:upperCorner>592280.94433594 424076.8491211</gml:upperCorner>
          </gml:Envelope>
        </ogc:BBOX>
        <ogc:Within>
          <gml:Polygon xmlns:gml="http://www.opengis.net/gml&quot;
            <gml:exterior>
              <gml:LinearRing>
                <gml:coordinates>139400 203697 139400 229770 159022 229770 159022
203697 139400 203697</gml:coordinates>
              </gml:LinearRing>
            </gml:exterior>
          </gml:Polygon>
        </ogc:Within>
      </ogc:And>
    </ogc:Filter>
  </wfs:Query>
</wfs:GetFeature>
Kind regards,
Roel
View this message in context: http://osgeo-org.1560.n6.nabble.com/Points-of-LinearRing-do-not-form-a-closed-linestring-tp5011496.html
GML coordinates tend to include commas
<gml:coordinates>0,0 100,0 100,100 0,100 0,0</gml:coordinates>
In addition, you are using WFS 1.1.0 which defaults to GML3 which considers coordinates as deprecated. Is is not strictly forbidden, I believe, but it would be better not to mix GML2 and GML3 dialects. Thus, use gml:posList.
-Jukka Rahkonen-
Roel De Nijs wrote:
Hello,
    <ogc:Filter
      <ogc:And>
        <ogc:BBOX>
  <gml:Envelope
  </gml:Envelope>
        </ogc:BBOX>
        <ogc:Within>
  <gml:exterior>
    <gml:LinearRing>
    </gml:LinearRing>
  </gml:exterior>
  </gml:Polygon>
        </ogc:Within>
      </ogc:And>
    </ogc:Filter>
  </wfs:Query>
</wfs:GetFeature>
Kind regards,
Roel
Everyone hates slow websites. So do we.
Make your web apps faster with AppDynamics Download AppDynamics Lite
for free today:
http://p.sf.net/sfu/appdyn_sfd2d_oct
Geoserver-users mailing list
On Fri, Oct 26, 2012 at 12:58 PM, Roel De Nijs <roel.denijs@anonymised.com> wrote:
Hello,
Mind, the error could also be coming from data reading, some databases do
not complain if you have rings in polygons that are not closed, but JTS surely
does
Our support, Your Success! Visit http://opensdi.geo-solutions.it for
more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi Jukka,
Thanks for your swift reply!
The GML dialects were mixed up simply due to my ignorance. I started with a WFS 1.0.0 request (which was sent by OpenLayers), but because I didn't manage to get it working I switched to WFS 1.1.0 and give that one a try.
When I use WFS 1.1.0 together with gml:posList the request is executed successfully. But when I switch back to WFS 1.0.0 and use gml:coordinates with commas I get a NullPointerException when parsing the Polygon.
Error:
java.lang.RuntimeException: Parsing failed for Polygon: java.lang.NullPointerException
Null
Request:
<wfs:GetFeature xmlns:wfs="http://www.opengis.net/wfs&quot; service="WFS" version="1.0.0" outputFormat="GML2" xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;&gt;
                        <ogc:And>
                                <ogc:BBOX>
                                        <gml:Box xmlns:gml="http://www.opengis.net/gml&quot; srsName="EPSG:31370">
                                                <gml:coordinates decimal="." cs="," ts=" ">-284279.94433594,-12078.599121097 592280.94433594,424076.8491211</gml:coordinates>
                                        </gml:Box>
                                </ogc:BBOX>
                                <ogc:Within>
                                        <gml:Polygon xmlns:gml="http://www.opengis.net/gml&quot; srsName="EPSG:31370">
                                                <gml:exterior>
                                                        <gml:LinearRing>
        <gml:coordinates decimal="." cs="," ts=" ">139400.25104111,203697.60407176 139400.25104111,229770.11674822 159022.6686784,229770.11674822 159022.6686784,203697.60407176 139400.25104111,203697.60407176</gml:coordinates>
                                                        </gml:LinearRing>
                                                </gml:exterior>
                                        </gml:Polygon>
                                </ogc:Within>
                        </ogc:And>
                </ogc:Filter>
        </wfs:Query>
</wfs:GetFeature>
Any ideas?
Kind regards,
Roel
-----Oorspronkelijk bericht-----
Van: Rahkonen Jukka [mailto:Jukka.Rahkonen@anonymised.com]
Verzonden: vrijdag 26 oktober 2012 13:39
Aan: 'geoserver-users@lists.sourceforge.net'
Onderwerp: Re: [Geoserver-users] Points of LinearRing do not form a closed linestring
-Jukka Rahkonen-
Roel De Nijs wrote:
Hello,
              <ogc:Filter
                      <ogc:And>
                              <ogc:BBOX>
      <gml:Envelope
      </gml:Envelope>
                              </ogc:BBOX>
                              <ogc:Within>
      <gml:exterior>
              <gml:LinearRing>
              </gml:LinearRing>
      </gml:exterior>
      </gml:Polygon>
                              </ogc:Within>
                      </ogc:And>
              </ogc:Filter>
      </wfs:Query>
</wfs:GetFeature>
Kind regards,
Roel
for free today:
Download AppDynamics Lite for free today:
Volg Aquafin op Facebook<https://www.facebook.com/AquafinNV&gt; | Twitter<https://twitter.com/aquafinnv&gt; | YouTube<http://www.youtube.com/channel/UCk_4P5BJ-MtEEDCkCsR_KqQ?feature=mhee&gt; | LinkedIN<http://www.linkedin.com/company/aquafin/products&gt;
Disclaimer: zie www.aquafin.be<http://www.aquafin.be> P Denk aan het milieu. Druk deze mail niet onnodig af.
