[Geoserver-users] polygon centroids showing up instead of polygons in Geoserver
I created a multi-polygon shapefile in arcGIS, but I did not create topology on it. When I open it in Geoserver, the shapefile is displayed as a series of points (centroid of each polygon), instead of showing the polygons. I did not calculate centroids for my polygons in ArcGIS. Does anyone know why this is happening, please?
Thank-you,
N
This communication is intended for the use of the recipient to which it is addressed, and may
contain confidential, personal, and or privileged information. Please contact the sender
immediately if you are not the intended recipient of this communication, and do not copy,
distribute, or take action relying on it. Any communication received in error, or subsequent
reply, should be deleted or destroyed.------------------------------------------------------------------------------------------------------------------------
Natalie O'Toole ha scritto:
You probably chose a style made for points instead of one made for
polygons.
Andrea Aime
OpenGeo - http://opengeo.org
