[Geoserver-users] Polygon svg fill problem
*I'm given several .svg symbols and asked to create sld for each of them.
When I try to see the symbology in QGIS, I have no problem. but when I
export that to sld in order to use in geoserver, I see weird symbols.
Then I tried to create the sld from the cookbook 2.17 I still cannot see
symbols as it is supposed to be. I don't know what else to do. It is a
really simple process, but I don't know what is the problem. I even tried to
use SLDEditor by SCISYS and no result there either.*
<?xml version="1.0" encoding="UTF-8"?><sld:StyledLayerDescriptor
xmlns="http://www.opengis.net/sld&quot; xmlns:sld="http://www.opengis.net/sld&quot;
xmlns:gml="http://www.opengis.net/gml&quot;
xmlns:ogc="http://www.opengis.net/ogc&quot; version="1.0.0">
  <sld:NamedLayer>
    <sld:Name/>
    <sld:UserStyle>
      <sld:Name>Default Styler</sld:Name>
      <sld:FeatureTypeStyle>
        <sld:Name>name</sld:Name>
        <sld:Rule>
          <sld:PolygonSymbolizer>
            <sld:Fill>
              <sld:GraphicFill>
                <sld:Graphic>
                  <sld:ExternalGraphic>
                    <sld:OnlineResource
xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:type="simple"
xlink:href="file:/C:/Program%20Files%20(x86)/GeoServer%202.13.4/data_dir/styles/ofiyolit+melanj.svg"/>
                    <sld:Format>image/svg+xml</sld:Format>
                  </sld:ExternalGraphic>
                  <sld:Size>20.0</sld:Size>
                </sld:Graphic>
              </sld:GraphicFill>
            </sld:Fill>
            <sld:Stroke>
              <sld:CssParameter name="stroke">#FF3333</sld:CssParameter>
            </sld:Stroke>
          </sld:PolygonSymbolizer>
        </sld:Rule>
      </sld:FeatureTypeStyle>
    </sld:UserStyle>
  </sld:NamedLayer>
</sld:StyledLayerDescriptor>
QGIS screen and the correct way it should be
<http://osgeo-org.1560.x6.nabble.com/file/t386208/qgis.png&gt;
Same symbol in Geoserver
<http://osgeo-org.1560.x6.nabble.com/file/t386208/geoserver.png&gt;
Symbol in inkscap
<http://osgeo-org.1560.x6.nabble.com/file/t386208/inksacpe.png&gt;
Sent from: http://osgeo-org.1560.x6.nabble.com/GeoServer-User-f3786390.html
It looks like the size is wrong, what happens if you leave the size parameters out?
Ian
Please share the SVG itself. I’m guessing it has some internal bounds definition, like view rectangle, limiting
it to the part of the SVG we’re seeing
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Hello list,
I've solved the problem. I compared the working svg file(burg02.svg) with my
owns and apparently SVG files I was using before had grids and that might be
the cause of the problem. When I turned off the grids, Geoserver was able to
render it the way it should be. Also, styles should be in the styles
directory.
Omer
Thanks for following up. Some comments inline below.
Hello list,
I’ve solved the problem. I compared the working svg file(burg02.svg) with my
Grids? What are they?
Also, styles should be in the styles directory.
Well yes, they really must be there, cannot be anywhere else. Or did you mean the SVGs?
"Grids What are they?"
In Inkscape, there is a grid option in the document properties(image below),
I turned them off.*
"Well yes, they really must be there, cannot be anywhere else. Or did you
mean the SVGs?"
*Yes, I'm sorry. I meant the SVG files must be in the styles directory*
<http://osgeo-org.1560.x6.nabble.com/file/t386208/Screenshot_1.png&gt;
