[Geoserver-users] PolygonExtraction rendering
Dear all, I have a precipitation data raster I need to style with value ranges. If I style it with a color map type = ramp the result is poor because of the raster resolution. So I’ve followed this rendering transformation tutorial in order to avoid the pixelated effect. But at a first glance using the gs:PolygonExtraction function I get the same result as the raster color ramp while I’ve hoped to get the contour lines drawn as polygons (as stated in the tutorial) which is a better result. Is it the expected result? Should I change some parameters? Thanks for your help. Bye Paolo
View this message in context: PolygonExtraction rendering
In order to add some details, I’ve combined the gs:PolygonExtraction function based style with the gs:Contour based style (pls see image).
View this message in context: Re: PolygonExtraction rendering
