[Geoserver-users] postgis SQL view - geography column not recognised
I am using
  • Geoserver 2.1.2 (have replicated this issue on 2.1.3 as well)
  • PostgreSQL 9.1.3 on x86_64-pc-linux-gnu, compiled by gcc-4.6.real (Ubuntu/Linaro 4.6.1-9ubuntu3) 4.6.1, 64-bit
  • POSTGIS=“1.5.3” GEOS=“3.2.2-CAPI-1.6.2” PROJ=“Rel. 4.7.1, 23 September 2009” LIBXML=“2.7.8” USE_STATS
  • Sun Java™ SE Runtime Environment (build 1.6.0_26-b03)
I have no problem creating layers by directly publishing tables from Postgis or Oracle 11g and can create SQL Views in oracle 11g but not Postgis.
I am having issues with SQL views connecting to a Postgis datasource with a table defined like so:
CREATE TABLE lightning (
id integer primary key,
timestamp text,
amplitude real,
duration integer,
type text,
strike_location geography(POINT, 4326)
CREATE INDEX lightning_gix ON lightning USING GIST ( strike_location );
However when I try to create an SQL view, for example:
select * from lightning
Then the geography column strike_location is not picked up and I see the log message:
WARN [geotools.jdbc] - Could not find mapping for ‘strike_location’, ignoring the column and setting the feature type read only
The layer can be created if I manually specify SRS and bounding Box it does not appear to have a location associated with it, layer preview doesn’t work and GML contains no lat lon information.
Any help would be appreciated.
Josh
Joshua,
does the user you are connecting with have permission to select from the view geography_columns (introduced when support for geographies was added)?
Can you "select * from geography_columns" as this user?
For GeoServer to recognise geometry columns in views, they must be registered in geometry_columns. I suspect a similar rule may apply to geography columns.
Kind regards,
Ben.
On 02/03/12 12:41, Joshua Groom wrote:
I am using
- Geoserver 2.1.2 (have replicated this issue on 2.1.3 as well)
- PostgreSQL 9.1.3 on x86_64-pc-linux-gnu, compiled by gcc-4.6.real (Ubuntu/Linaro 4.6.1-9ubuntu3) 4.6.1, 64-bit
- POSTGIS="1.5.3" GEOS="3.2.2-CAPI-1.6.2" PROJ="Rel. 4.7.1, 23 September 2009" LIBXML="2.7.8" USE_STATS
- Sun Java(TM) SE Runtime Environment (build 1.6.0_26-b03)
   timestamp text,
   amplitude real,
   duration integer,
   type text,
WARN [geotools.jdbc] - Could not find mapping for 'strike_location', ignoring the column and setting the feature type read only
The layer can be created if I manually specify SRS and bounding Box it does not appear to have a location associated with it, layer preview doesn't work and GML contains no lat lon information.
Josh
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
Yes the postgres user which geoserver is using can see the table and the contents are:
josh=# select * from geography_columns;
f_table_catalog | f_table_schema | f_table_name | f_geography_column | coord_dimension | srid | type
josh | public | lightning | strike_location | 2 | 4326 | Point
Josh
________________________________________
From: Ben Caradoc-Davies [Ben.Caradoc-Davies@anonymised.com]
Sent: Friday, 2 March 2012 6:09 p.m.
To: Joshua Groom
Subject: Re: [Geoserver-users] postgis SQL view - geography column not recognised
Joshua,
geography columns.
Kind regards,
Ben.
I am using
   timestamp text,
   amplitude real,
   duration integer,
   type text,
Josh
Software Engineer
Is this a geotools bug?
When creating a layer from a table the strike_location geography binding is correctly identified by the org.geotools.jdbc.JDBCFeatureSource class as com.vividsolutions.jts.geom.Point. This happens because the SQLDialect subclass org.geotools.data.postgis.PostGisDialect is called to determine the mapping
dialect.getMapping(columns, cx) is called, this method looks up the geography_columns in geography_columns table.
In the SQL view case the sqlType is 1111 but the binding is null. There is different logic to retrieve the binding it uses
dialect.registerSqlTypeNameToClassMappings(sqlTypeNameToClassMappings) but this hashmap doesn't have a mapping for the "geography" type.
This seems like a geotools bug, and from my quick look at the trunk it doesn't look like it has been fixed.
So any suggestions for known good versions of geotools/geoserver to try?
The reason I need this functionality is to allow me to publish a layer where users can do spatial and time based queries, sending the time parameter into the SQL view would let me achieve that. Open to work arounds...
Josh
Sent: Tuesday, 6 March 2012 10:01 a.m.
To: Ben Caradoc-Davies
Josh
To: Joshua Groom
Joshua,
geography columns.
Kind regards,
Ben.
I am using
   timestamp text,
   amplitude real,
   duration integer,
   type text,
Josh
Software Engineer
Try before you buy = See our experts in action!
The most comprehensive online learning library for Microsoft developers
is just $99.99! Visual Studio, SharePoint, SQL - plus HTML5, CSS3, MVC3,
Metro Style Apps, more. Free future releases when you subscribe now!
http://p.sf.net/sfu/learndevnow-dev2
Geoserver-users mailing list
Quite likely, the test harness for geography columns has no checks for sql views
dialect.registerSqlTypeNameToClassMappings(sqlTypeNameToClassMappings) but this hashmap doesn’t have a mapping for the “geography” type.
This seems like a geotools bug, and from my quick look at the trunk it doesn’t look like it has been fixed.
The suggestion would be to:
  1. do a bug report
  2. if you want to have a fix in the next release (2.1.4), do it yourself within a few days:
    add a junit test, fix the bug, submit a patch to geotools to have your changes
    incorporated (mind, almost no fixes get in without a test, it’s not optional)
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
mob: +39 339 8844549
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
Ok,
Well I will aim to send a patch to geotools then. So I gather that there is an upcoming release of geoserver that will include the 2.7.5 release of geotools.
Is http://svn.osgeo.org/geotools/trunk what I should develop my fix against?
Josh
From: andrea.aime@anonymised.com [andrea.aime@anonymised.com84…] on behalf of Andrea Aime [andrea.aime@anonymised.com]
Sent: Tuesday, 6 March 2012 10:14 p.m.
To: Joshua Groom
Cc: Ben Caradoc-Davies; geoserver-users@lists.sourceforge.net
On Tue, Mar 6, 2012 at 6:23 AM, Joshua Groom <Joshua.Groom@anonymised.com> wrote:
  1. do a bug report
Ing. Andrea Aime
Tech lead
Yes, please, but also backport to the stable branch, from which 2.7.5 will be released (in GeoServer 2.1.4[?]):
http://svn.osgeo.org/geotools/branches/2.7.x/
Trunk will become GeoTools 8.0 (the leading "2." is being dropped) and be included with GeoServer 2.2.
Kind regards,
Software Engineer
The fix to this problem for me is just adding a mapping to PostGISDialect.java however the test suite is a little harder to get running so I have not yet submitted a patch.
For anyone who has been following this:
There is a work around for this issue though. Just manually edit the featuretype.xml file in geoserver data_dir to contain the following snippet that defines the geometry for the column:
<metadata>
    <entry key="JDBC_VIRTUAL_TABLE">
      <virtualTable>
        <name>test-dialect</name>
        <sql>select * from lightning</sql>
        <geometry>
          <name>strike_location</name>
          <type>Point</type>
          <srid>4326</srid>
        </geometry>
      </virtualTable>
    </entry>
  </metadata>
When the layer is reloaded you will be able to edit it as normal.
Josh
Sent: Wednesday, 7 March 2012 4:40 p.m.
To: Joshua Groom
Cc: Andrea Aime; geoserver-users@lists.sourceforge.net; geotools-devel@anonymised.coms.sourceforge.net
Kind regards,
Software Engineer
On Tue, Mar 13, 2012 at 11:20 PM, Joshua Groom
In order to run the tests you need to play a postgis.properties file
in your home directory's .geotools folder (e.g.,
/home/aaime/.geotools/postgis.properties for
me, on a Linux system, on other OS the position will be different) and
fill it with enough info to connect to an empty
postgis database that the tests will run onto (creating tables and so on).
The contents of the file look like the following:
passwd=pwd
password=pwd
user=cite
port=5432
url=jdbc\:postgresql\:gttest
host=localhost
database=gttest
driver=org.postgresql.Driver
(yes, there is redundant info there, there is a jira to fix that,
which nobody has worked on so far)
Ing. Andrea Aime
Tech lead
