[Geoserver-users] Printing module
Hello again,
First, thank everyone for their help.
I keep trying to use the print module but the create.json endpoint fails.
com.itextpdf.text.DocumentException: org.mapfish.print.InvalidJsonValueException: spec.layers[0].baseURL has an invalid value: https://…/ows?SERVICE=WMS& (java.util.HashMap cannot be cast to org.mapfish.print.config.HostMatcher)
A little context:
1.- I am using version 2.24.0 of Geoserver with Postgis Database (OSM)
2.- I am using docker-compose and nginx with proxy for GS and https
3.- I included the commons-httpclient-3.1.jar library to solve initial problems.
4.-https:…/geoserver/pdf/info.json works and includes this url:
“printURL”: “https://…/geoserver/pdf/print.pdf”,
“createURL”: “https://…/geoserver/pdf/create.json”
5.- I tried many host entries in Printing/config.yaml.
Somebody could help me?
Greetings
We did a lot of changes recently to the library used by the print module, and while there some tests there are not a lot of tests in place so we depend on public feedback.
What do you mean about initial problems and http client?1
(I do not use the print module myself but I do try and check everything is packaged okay)
Jody Garnett
Well i’ll try to use http client.
Wich updated version are you talking about?
Regards
Jody Garnett
On Sat, Feb 24, 2024 at 12:57 PM Sailing Control - Kiko <kiko.de.carlos@anonymised.com> wrote:
Hello again,
A little context:
Greetings
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
