hi
I’ve setup geoserver 2.2.4 on windows 7 64 bit machine. Everything works fine with the builtin data.
However, if I try to add a new layer, following the tutorial, the new layer doesn’t appear on the layers list.
I’ve created a workspace, data store for my data. after the store is created, I try to create a new layer. In the new layer page, I set the projection and bbox and click save. There are no errors. When I go to the layers page, my new layer is missing.
I’ve tried that for both shapefiles and geotiff rasters.
The same procedure worked on a 32 bit machine.
Thanks
Yehiyam Livneh
Sent by emoze push mail
This message (including any attachments) issued by RAFAEL- ADVANCED DEFENSE SYSTEMS LTD. (hereinafter “RAFAEL”) contains confidential information intended for a specific individual and purpose, may constitute information that is privileged or confidential or otherwise protected from disclosure. If you are not the intended recipient, you should contact us immediately and thereafter delete this message from your system. You are hereby notified that any disclosure, copying, dissemination, distribution or forwarding of this message, or the taking of any action based on it, is strictly prohibited. If you have received this e-mail in error, please notify us immediately by e-mail mailto:lawraf@…5415… and completely delete or destroy any and all electronic or other copies of the original message and any attachments thereof.
Yehiyam
could you kindly attach the geoserver log (containing store creation and layer visualization)?Cheers,
Carlo
2013/2/10 Livneh Yehiyam <yehil@anonymised.com5…>
hi
Thanks
Yehiyam Livneh
This message (including any attachments) issued by RAFAEL- ADVANCED DEFENSE SYSTEMS LTD. (hereinafter “RAFAEL”) contains confidential information intended for a specific individual and purpose, may constitute information that is privileged or confidential or otherwise protected from disclosure. If you are not the intended recipient, you should contact us immediately and thereafter delete this message from your system. You are hereby notified that any disclosure, copying, dissemination, distribution or forwarding of this message, or the taking of any action based on it, is strictly prohibited. If you have received this e-mail in error, please notify us immediately by e-mail mailto:lawraf@anonymised.com and completely delete or destroy any and all electronic or other copies of the original message and any attachments thereof.
Free Next-Gen Firewall Hardware Offer
Buy your Sophos next-gen firewall before the end March 2013
and get the hardware for free! Learn more.
http://p.sf.net/sfu/sophos-d2d-feb
Geoserver-users mailing list
Dott. Carlo Cancellieri
@cancellieric
Software Engineer
Via Poggio alle Viti 1187
mobile: +39 3371094494
On Sun, Feb 10, 2013 at 4:43 PM, Livneh Yehiyam <yehil@anonymised.com> wrote:
hi
Hum… I have vague memories of Windows 7 undoing changes made in c:\program files as a way
to protect programs, or something like that.
If the data dir is in c:\program files\geoserver it may well be that’s the operating system playing tricks
on you
See here:
http://serverfault.com/questions/165278/windows-7-and-program-files-protection
I believe that the windows installer should be reworked to put configuration files in the Windows
mandated places… Not sure, haven’t been using Windows in a long time, the current installer
I believe was created by Mike (cc’ed) a long time ago (Windows XP times if memory serves me rigth)
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
Just for detail's sake:
The way we're doing things right now isn't Windows-approved (the data_dir is in %PROGRAMFILES% when it really "should" be in %USERPROFILE%) but it should still work. Running as a service gives you full write permissions to the %PROGRAMFILES% directory.
Mike Pumphrey
OpenGeo - http://opengeo.org
hi
I've setup geoserver 2.2.4 on windows 7 64 bit machine. Everything works
layer doesn't appear on the layers list.
I've created a workspace, data store for my data. after the store is
I've tried that for both shapefiles and geotiff rasters.
Hum.. I have vague memories of Windows 7 undoing changes made in
If the data dir is in c:\program files\geoserver it may well be that's the
on you
See here:
mandated places... Not sure, haven't been using Windows in a long time, the
current installer
I believe was created by Mike (cc'ed) a long time ago (Windows XP times if
On Tue, Feb 12, 2013 at 1:33 AM, Mike Pumphrey <mike@anonymised.com> wrote:
Just for detail’s sake:
The way we’re doing things right now isn’t Windows-approved (the data_dir is in %PROGRAMFILES% when it really “should” be in %USERPROFILE%) but it should still work. Running as a service gives you full write permissions to the %PROGRAMFILES% directory.
Ah, interesting, so it seems the changes are going to be rolled back only if GeoServer is started interactively…
which is probably how people start it if they are just testing it, as opposed to trying to run it in production.
Ing. Andrea Aime
@geowolf
Technical Lead
mike@
to
if GeoServer is started interactively...
Bingo. Maybe this can be added to the documentation/download page? It's not
the most known thing to the average windows user & certain users security
setups can make it worse. I've run into this sort of thing making desktop
apps. Silly, Microsoft.
View this message in context: http://osgeo-org.1560.n6.nabble.com/problem-adding-layer-tp5033308p5034001.html
