[Geoserver-users] Problem with on th efly projection between 27572 and 2154
I just suscribed to this user group to share with you an issue and the solution.
Situation :
  • Geoserver 2.12.3 (olders have been tested too with same observations)
  • A first layer is created to load a shape projected in 27572
  • A second one is created to load a raster projected in 2154
  • An agregation is created to mix these two layers, projected in 27572.
Problem :
  • The shape is not well placed on the raster, not very far but not good.
If I compare the definition of the projection and the projection on https://epsg.io/, I can see that there is some differences (parameters TOWGS84 is missing, some values are differents…).
I can then use epsg_overrides.properties to define the projection given in epsg.io.
Unfortunately, the result is worst.
After further try, I mixed the native parameters of 27572 known in GeoServer and official parameters given on epsg.io and obtain something good :
27572=PROJCS[“NTF (Paris) / Lambert zone II”,GEOGCS[“NTF (Paris)”,DATUM[“Nouvelle_Triangulation_Francaise_Paris”,SPHEROID[“Clarke 1880 (IGN)”,6378249.2,293.4660212936269,AUTHORITY[“EPSG”,“7011”]],TOWGS84[-168,-60,320,0,0,0,0],AUTHORITY[“EPSG”,“6807”]],PRIMEM[“Paris”, 2.5969213, AUTHORITY[“EPSG”,“8903”]],UNIT[“grade”,0.015707963267948967],AXIS[“Geodetic longitude”, EAST],AXIS[“Geodetic latitude”, NORTH],AUTHORITY[“EPSG”,“4807”]],PROJECTION[“Lambert_Conformal_Conic_1SP”, AUTHORITY[“EPSG”,“9801”]],PARAMETER[“central_meridian”, 0.0],PARAMETER[“latitude_of_origin”, 52.0],PARAMETER[“scale_factor”, 0.99987742],PARAMETER[“false_easting”, 600000.0],PARAMETER[“false_northing”, 2200000.0],UNIT[“m”, 1.0],AXIS[“Easting”, EAST],AXIS[“Northing”, NORTH],AUTHORITY[“EPSG”,“27572”]]
I hope it could help.
Clément
background
Clément Diot
SYSTEL SA
logo
c.diot@anonymised.com
Phone: +33 5 46 44 57 20
The is for the detailed research? Are you in position to make a big report (preferably with sample data attached as that is often frustrating to procure).
Jody Garnett
I reported your issue to the geotools bug tracker: Accuracy issue reprojecting between EPSG:27572 and EPSG:2154
There are two troubles:
  • This is an older version of GeoServer so I would like to ask you to test a newer version (preferably a nightly build). I am not sure the last time the EPSG database was updated.
  • The bug report needs either some sample data to show the problem, or even a sample coordinates (So we can try out the transformation and show the problem, and then try out the fix and show that it is fixed).
Can you transform a test point please and let me know what the correct transformed coordinate is?
Jody Garnett
