[Geoserver-users] problem with Proxy Base URL as from version 2.19
Hello,
I do have the same problem as posted in: https://sourceforge.net/p/geoserver/mailman/message/37250476/
When geoserver is behind a reverse proxy as nginx and when "Proxy Base URL" is not empty in the global setting, it is not possible to access the web user interface anymore. I also did some tests, and this issue starts at version 2.19.
This is very annoying.
When "Proxy Base URL" is empty, you can login to the webui, but a wfs or wms?request=GetCapabilities&service will not be given the correct xlinks ( xlink:href="https://proxy_url_name/wfs") but will show (xlink:href="http://servername:8080/geoserver/wfs (or wms)")
When "Proxy Base URL" is not empty (https://proxy_url_name), then it is not possible to login via the webinterface.
Is it possible to solve this?
thanks.
Frans Fierens
Hi Frans,
maybe it just requires a different set up? These two servers are using nginx proxying, and a proxy base URL,
but the UI works, as you can see:
https://gs-main.geosolutionsgroup.com/geoserver/web/
http://gs-stable.geosolutionsgroup.com/geoserver/web/
One is a 2.20.x, the other is a nightly build from the developer series.
Unfortunately I don’t know exactly how they are set up NGINX wise, but I can tell you the proxy base URL configured in GeoServer
is simple, e.g. “https://gs-main.geosolutionsgroup.com/geoserver/
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
Thanks Andrea,
I already tried to configure the nginx but without success. It would be interesting to get more info on the nginx config. There are also other issues to deal when using this option: you give internet access to the admin pages (which I would prefer not to do).
best regards,
Frans
On 02/08/2022 18:09, Andrea Aime wrote:
Hi Frans,
On Tue, Aug 2, 2022 at 3:10 PM Frans Fierens <fierens@anonymised.com> wrote:
Hello,
When geoserver is behind a reverse proxy as nginx and when “Proxy Base
URL” is not empty in the global setting, it is not possible to access
When “Proxy Base URL” is empty, you can login to the webui, but a wfs or
( xlink:href=“https://proxy_url_name/wfs”) but will show
(xlink:href=“http://servername:8080/geoserver/wfs (or wms)”)
When “Proxy Base URL” is not empty (https://proxy_url_name), then it is
thanks.
Frans Fierens
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Geoserver-users@anonymised.comge.net
Andrea Aime
== GeoServer Professional Services from the experts!
Visit http://bit.ly/gs-services-us for more information. == Ing. Andrea Aime @geowolf Technical Lead
GeoSolutions Group phone: +39 0584 962313
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail
Frans Fierens   [<fierens@anonymised.com>](mailto:fierens@anonymised.com..11515...)
Medewerker van de Vlaamse Milieumaatschappij (VMM, [http://www.vmm.be](http://www.vmm.be)) aangesteld bij de Intergewestelijke Cel voor het Leefmilieu (IRCEL).
Gaucheretstraat 92-94
1030 Brussel
[http://www.irceline.be](http://www.irceline.be)
[http://twitter.com/SMOG_BE](http://twitter.com/SMOG_BE)
[https://www.facebook.com/ircel.celine](https://www.facebook.com/ircel.celine)
Tel 00 32(0)2 227 56 71
GSM 00 32(0)494 62 91 40
Skype Frans_JMC.Fierens
In our case we want to give internet access. Unfortunately I did not set it up, and I have no experience
with Nginx myself, so I can’t get into more details, sorry. Hopefully someone else on this list is more
proficient with deployments.
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Hi Frans,
I lodged the original issue about this. What I have done is set the proxy-base url for the workspace and left the Global proxy-base url unset. This allows me to access the admin pages.
Sent: Wednesday, 3 August 2022 2:26 AM
To: Andrea Aime andrea.aime@anonymised.com
Subject: Re: [Geoserver-users] problem with Proxy Base URL as from version 2.19
Thanks Andrea,
best regards,
Frans
Hi Frans,
Hello,
thanks.
Frans Fierens
Andrea Aime
Frans Fierens   [<fierens@anonymised.com>](mailto:fierens@anonymised.com)
Medewerker van de Vlaamse Milieumaatschappij (VMM, [http://www.vmm.be](https://aus01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.vmm.be%2F&data=05%7C01%7Cgraham.humphries%40stategrowth.tas.gov.au%7C44b6a4196cde468dde9808da74a3e9a2%7C64ebab8accf44b5ca2d32b4e972d96b2%7C0%7C0%7C637950544616391380%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=heqFTVJNkgNWyEMJOf4pHvWL%2FbimWVfdVLLprTqLrwo%3D&reserved=0)) aangesteld bij de Intergewestelijke Cel voor het Leefmilieu (IRCEL).
1030 Brussel
[http://www.irceline.be](https://aus01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.irceline.be%2F&data=05%7C01%7Cgraham.humphries%40stategrowth.tas.gov.au%7C44b6a4196cde468dde9808da74a3e9a2%7C64ebab8accf44b5ca2d32b4e972d96b2%7C0%7C0%7C637950544616391380%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=A97jxYizBdYC%2F%2Fk9YK6BThhGgibMqI43zRNgVYrwlGA%3D&reserved=0)
[http://twitter.com/SMOG_BE](https://aus01.safelinks.protection.outlook.com/?url=http%3A%2F%2Ftwitter.com%2FSMOG_BE&data=05%7C01%7Cgraham.humphries%40stategrowth.tas.gov.au%7C44b6a4196cde468dde9808da74a3e9a2%7C64ebab8accf44b5ca2d32b4e972d96b2%7C0%7C0%7C637950544616391380%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=BYMwOtrAmIx9EChhpk42MqnUya0wNZdg1TwVuxWRYUM%3D&reserved=0)
[https://www.facebook.com/ircel.celine](https://aus01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.facebook.com%2Fircel.celine&data=05%7C01%7Cgraham.humphries%40stategrowth.tas.gov.au%7C44b6a4196cde468dde9808da74a3e9a2%7C64ebab8accf44b5ca2d32b4e972d96b2%7C0%7C0%7C637950544616391380%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=1ADJes272Crpk50aSOHroivzBkVusnOzR08vO2UFNY4%3D&reserved=0)
Thx Graham.
This is indeed a solution. But not everything is solved: a wfs/wms GetCapabilities request will rely on the Global proxy-base url. It seems that the “online resource” option in the wfs/wms service section is not being used (?)
To illustrate this:
  1. GetCapabilities using geoserver v2.18.6: https://geo.irceline.be/wfs?request=GetCapabilities&service : the xlinks are correctly pointing to the proxy url https://geo.irceline.be/wfs. Global proxy-base url=https://geo.irceline.be, admin pages are accessible.
  2. GetCapabilities using geoserver v2.21.0 with empty Global proxy-base url: https://geonew.irceline.be/wfs?request=GetCapabilities&service : the xlinks are pointing to http://georocky/geoserver/wfs and NOT to the correct proxy url https://geonew.irceline.be/wfs. This will only be correct when the Global proxy-base url is not empty … but then the admin pages are not accessible anymore.
catch 22 …
best regards,
Frans
On 03/08/2022 02:22, Humphries, Graham wrote:
Hi Frans,
Cc: geoserver-users@anonymised.comge.net
Thanks Andrea,
best regards,
Frans
Hi Frans,
Hello,
thanks.
Frans Fierens
Geoserver-users@anonymised.comrceforge.net
Andrea Aime
Frans Fierens   [<fierens@anonymised.com>](mailto:fierens@anonymised.com.)
1030 Brussel
CONFIDENTIALITY NOTICE AND DISCLAIMER
The information in this transmission may be confidential and/or protected by legal professional privilege, and is intended only for the person or persons to whom it is addressed. If you are not such a person, you are warned that any disclosure, copying or dissemination of the information is unauthorised. If you have received the transmission in error, please immediately contact this office by telephone, fax or email, to inform us of the error and to enable arrangements to be made for the destruction of the transmission, or its return at our cost. No liability is accepted for any unauthorised use of the information contained in this transmission.
1030 Brussel
Hi Frans, hi all,
I had running a GeoServer >2.19 with a nginx in the past. I remember some problems with unwanted redirects and similar when behind the proxy.
Besides setting the “Proxy Base URL” I had to set the ENV VAR “GEOSERVER_CSRF_WHITELIST”, like GEOSERVER_CSRF_WHITELIST=my-geoserver.server.de to get the Web-UI and all services fully functional.
Not sure if it was exactly the same problems you had but maybe you want to give it a shot and report back here.
Best regards
Chris
On 03.08.22 08:57, Frans Fierens wrote:
Thx Graham.
To illustrate this:
catch 22 …
best regards,
Frans
Hi Frans,
Thanks Andrea,
best regards,
Frans
Hi Frans,
Hello,
thanks.
Frans Fierens
Andrea Aime
1030 Brussel
1030 Brussel
- Earning your support instead of buying it, but Ian Turton: [http://www.ianturton.com/talks/foss4g.html#/](http://www.ianturton.com/talks/foss4g.html#/)
- The GeoServer user list posting guidelines: [http://geoserver.org/comm/userlist-guidelines.html](http://geoserver.org/comm/userlist-guidelines.html)
If you want to request a feature or an improvement, also see this: [https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer](https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer)
[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-users](https://lists.sourceforge.net/lists/listinfo/geoserver-users)
Wow! This is indeed the solution, together with the nginx config below (the allow/deny is to deny internet access). Thanks!!
best regards
Frans
location /geoserver/ {
allow x.x.x.x;
deny all;
proxy_pass http://yourgeoserver:8080/geoserver/;
proxy_pass_header Set-Cookie;
proxy_set_header Host $host;
proxy_set_header X-Forwarded-Proto $scheme;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
location / {
allow x.x.x.x;
deny all;
On 03/08/2022 15:58, Christian Mayer wrote:
Hi Frans, hi all,
Best regards
Chris
1030 Brussel
Thx Graham.
To illustrate this:
catch 22 …
best regards,
Frans
Hi Frans,
Cc: geoserver-users@anonymised.comforge.net
Thanks Andrea,
best regards,
Frans
Hi Frans,
Hello,
thanks.
Frans Fierens
Geoserver-users@anonymised.com.sourceforge.net
Andrea Aime
Frans Fierens   [<fierens@anonymised.com>](mailto:fierens@anonymised.com15...)
1030 Brussel
1030 Brussel
[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@anonymised.comsourceforge.net)
If you think it would help future users with this problem you could add this information with an outline of the problem and this solution to the running in production pages of the user manual
Ian
Ian Turton
