[Geoserver-users] Problem with secure layers and with different roles
Hello
I have tried to install both GeoServer 2.7.0 and 2.6.3 on Windows and have get the same problem in both cases.
I have two different workspaces and two different users that should have access to one of the workspaces each.
UserA should only see WorkspaceA and UserB should only see WorkspaceB!
I configure as good as I could, looking at those tutorial I have found, but when I look at the result from the client side (ArcView and QGIS) it doesn’t look as expected.
It seem as one of the users/workspaces take over from the other. It works with one login, but as soon as I add the next one the problem arise.
Do anyone know if there is a problem with GeoServer security with the configuration I use?
Best Regards
Johan
Johan Hallgren
+46 (0)70 200 41 01
johan.hallgren@anonymised.com
GISZEAL AB
www.giszeal.se
logo-red
On Mon, Apr 27, 2015 at 12:54 PM, Johan Hallgren <johan.hallgren@anonymised.com>
wrote:
Hello
What do you mean by "take over"?
Are you sure the extra layers you're seeing are not global layer groups?
If that's not the case, can you provide step by step instructions on how
to reproduce using the GeoServer
standard install, it already comes with a few workspaces you can use.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Ohh, differens problems.
I reinstalled 2.6.3. I get the feeling that it worked better there.
Now it seems to work better when I use QGIS.
I also want it to work with ArcGIS (10.2.2).
The data-security looks like:
In ArcGIS GetLayers (GetCapabilities) doesn’t show any layers. Even if I give the right password. It only shows public layers.
I also tried to change the catalog mode to MIXED or CHALLENGE but with CHALLENGE mode I get the massage Failed to connect to the server.
Do you know if there is some special settings in GeoServer for ArcGIS clients?
/Johan
Johan Hallgren
+46 (0)70 200 41 01
johan.hallgren@…7037…
GISZEAL AB
www.giszeal.se
logo-red
From: andrea.aime@…84… [mailto:andrea.aime@…84…] On Behalf Of Andrea Aime
Sent: den 27 april 2015 13:59
To: Johan Hallgren
Subject: Re: [Geoserver-users] Problem with secure layers and with different roles
On Mon, Apr 27, 2015 at 12:54 PM, Johan Hallgren <johan.hallgren@…7037…> wrote:
Hello
What do you mean by “take over”?
Are you sure the extra layers you’re seeing are not global layer groups?
If that’s not the case, can you provide step by step instructions on how to reproduce using the GeoServer
Ing. Andrea Aime
@geowolf
Technical Lead
On Tue, Apr 28, 2015 at 9:35 AM, Johan Hallgren <johan.hallgren@anonymised.com>
CHALLENGE mode I get the massage *Failed to connect to the server*.
clients?
Personally I don't, no ESRI software here, but as a reference, for software
that have problems using
http basic authentication we have the authkey module as an alternative:
http://docs.geoserver.org/2.6.x/en/user/community/authkey/index.html
But probably other people on this mailing list have experience with ArcGIS
Ing. Andrea Aime
@geowolf
Technical Lead
Hello again
I couldn’t find the “authentication filter named authkey”.
This is what I have:
/johan
Johan Hallgren
+46 (0)70 200 41 01
GISZEAL AB
www.giszeal.se
logo-red
Sent: den 28 april 2015 09:47
To: Johan Hallgren
On Tue, Apr 28, 2015 at 9:35 AM, Johan Hallgren <johan.hallgren@…7037…> wrote:
Personally I don’t, no ESRI software here, but as a reference, for software that have problems using
Ing. Andrea Aime
@geowolf
Technical Lead
On Tue, Apr 28, 2015 at 11:16 AM, Johan Hallgren <johan.hallgren@anonymised.com>
wrote:
Hello again
Did you install the authkey community module first? :slight_smile:
Being a community module, you can only find it among the nightly builds:
http://ares.boundlessgeo.com/geoserver/2.6.x/community-latest/geoserver-2.6-SNAPSHOT-authkey-plugin.zip
I still hope others will chime in regarding ArcGis behavior, the authkey
module is unfortunately unsupported (as all community modules).
Ing. Andrea Aime
@geowolf
Technical Lead
Sorry, didn’t understand and couldn’t find the informationL
Thanks!
/Johan
Johan Hallgren
+46 (0)70 200 41 01
GISZEAL AB
www.giszeal.se
logo-red
Sent: den 28 april 2015 11:22
To: Johan Hallgren
On Tue, Apr 28, 2015 at 11:16 AM, Johan Hallgren <johan.hallgren@…7037…> wrote:
Hello again
I still hope others will chime in regarding ArcGis behavior, the authkey module is unfortunately unsupported (as all community modules).
Ing. Andrea Aime
@geowolf
Technical Lead
