[Geoserver-users] problem with the ExtrnalGraphic
Have been able to replicate this issue on our instance of Geoserver 2.1.1 with an ExternalGraphic. Rendering the WMS output as image/png, the ExternalGraphic shows up. However, rendering the WMS output as application/pdf, the ExternalGraphic is ignored. Sounds like a bug with GeoServer, not something particularly related to our SLDs, unfortunately.
Babak Dehghenpour
TU Delft Library/SSC ICT
Library Innovation
Developer
Room 2.32
Prometheusplein 1,Postbus 98, 2628 ZC Delft
( 015-2789437
Fax 015-2572060
8 b.dehghenpour@...1570...
8 library.tudelft.nl
-----Original Message-----
Sent: dinsdag 27 september 2011 11:04
To: Andrea Aime
Subject: Re: [Geoserver-users] REST Problems in 1.7x series
Ok,
thanks for your help Andrea.
I will keep waiting for a while if someone in the list would have hands-on experience in that particular problem. If not, we'll choose our way, whether it'd be a bug fix or upgrading or some other solution, and proceed our journey along with that.
mika
On Tue, 27 Sep 2011 10:52:17 +0200, Andrea Aime <andrea.aime@...1107...> wrote:
On Tue, Sep 27, 2011 at 10:05 AM, <mika@...1541...> wrote:
Hi Andrea,
so you think this is a bug in the old branch, which either ought to
be fixed or upgrade the whole Geoserver into newer one, in order to
get the uploading process and the requests work as expected?
I can't know without analyzing the situation directly, but it may be
likely since at the 1.7.x times rest config was pretty new and very
few people used it.
At the same time, I can't know if the issue has been fixed in the
meantime, I'm not the one that uses restconfig in anger at my company.
That said, uploading a geotiff file seems like a common use case, so I
would assume it should be working fine in the 2.1.x series
The thing is, on the 1.7.x (or 2.0.x) series you're on your own, if
you try it out on 2.1.x and it's not working at least you can report
the bug and hope someone will fix it (though, relying on the community
will mean there is no guarantee on when it will be fixed), while on
the old series the development is fully stopped.
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
All the data continuously generated in your IT infrastructure contains a definitive record of customers, application performance, security threats, fraudulent activity and more. Splunk takes this data and makes sense of it. Business sense. IT sense. Common sense.
http://p.sf.net/sfu/splunk-d2dcopy1
Geoserver-users mailing list
