I’m using GeoServer 2.6.0, and I’ve correctly published a 3-band raster, on which I have applied a style with coninuous values to view only the first band.
The problem is that when I open the Layer Preview, I see the raster with only one color, but zooming I’m able to see the correct style with all colors that I’ve applied.
Does anyone knows why?
Thank you for your help
Best regards,
Marco
Dear Marco,
we need more details to be able to help you out as well as, probably,
some sample date.
I would start from the info below:
- geoserver version
- SLD used
- output of the gdalinfo on the data being used
- which plugin you are using (geotiff? imagemosaic? )
Simone Giannecchini
GeoSolutions for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Fri, May 15, 2015 at 10:19 AM, Marco Colasurdo <m.colasu86@anonymised.com> wrote:
I'm using GeoServer 2.6.0, and I've correctly published a 3-band raster, on
band.
only one color, but zooming I'm able to see the correct style with all
colors that I've applied.
Best regards,
Marco------------------------------------------------------------------------------
One dashboard for servers and applications across Physical-Virtual-Cloud
Widest out-of-the-box monitoring support with 50+ applications
Performance metrics, stats and reports that give you Actionable Insights
Deep dive visibility with transaction tracing using APM Insight.
IT infrastructure & Application Monitoring Tool - ManageEngine Applications Manager
Geoserver-users mailing list
Geoserver version : 2.6.0
SLD used is:
<?xml version="1.0" encoding="UTF-8"?> Name Title 1Gdalinfo output:
Size is 831, 698
Coordinate System is:
GEOGCS[“ETRS89”,
DATUM[“European_Terrestrial_Reference_System_1989”,
SPHEROID[“GRS 1980”,6378137,298.2572221010002,
AUTHORITY[“EPSG”,“7019”]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY[“EPSG”,“6258”]],
PRIMEM[“Greenwich”,0],
UNIT[“degree”,0.0174532925199433],
AUTHORITY[“EPSG”,“4258”]]
Origin = (-17.000000000000000,80.000000000000000)
Pixel Size = (0.067388688327316,-0.067335243553009)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( -17.0000000, 80.0000000) ( 17d 0’ 0.00"W, 80d 0’ 0.00"N)
Lower Left ( -17.0000000, 33.0000000) ( 17d 0’ 0.00"W, 33d 0’ 0.00"N)
Upper Right ( 39.0000000, 80.0000000) ( 39d 0’ 0.00"E, 80d 0’ 0.00"N)
Lower Right ( 39.0000000, 33.0000000) ( 39d 0’ 0.00"E, 33d 0’ 0.00"N)
Center ( 11.0000000, 56.5000000) ( 11d 0’ 0.00"E, 56d30’ 0.00"N)
Band 1 Block=831x1 Type=Float32, ColorInterp=Gray
Min=0.000 Max=0.950
Minimum=0.000, Maximum=0.950, Mean=0.389, StdDev=0.214
NoData Value=-9999
Metadata:
STATISTICS_MAXIMUM=0.94999998807907
STATISTICS_MEAN=0.38901697872035
STATISTICS_MINIMUM=0
STATISTICS_STDDEV=0.21422942111317
Band 2 Block=831x1 Type=Float32, ColorInterp=Undefined
Min=20.000 Max=372.000
Minimum=20.000, Maximum=372.000, Mean=63.815, StdDev=94.819
NoData Value=-9999
Metadata:
STATISTICS_MAXIMUM=372
STATISTICS_MEAN=63.815256912478
STATISTICS_MINIMUM=20
STATISTICS_STDDEV=94.81900812511
Band 3 Block=831x1 Type=Float32, ColorInterp=Undefined
Min=-0.004 Max=0.330
Minimum=-0.004, Maximum=0.330, Mean=0.055, StdDev=0.065
NoData Value=-9999
Metadata:
STATISTICS_MAXIMUM=0.32969999313354
STATISTICS_MEAN=0.055351323014081
STATISTICS_MINIMUM=-0.0040000001899898
STATISTICS_STDDEV=0.064768450167203
The plugin used is ImageMosaic.
Thank you,
Marco
2015-05-18 12:08 GMT+02:00 Simone Giannecchini <simone.giannecchini@anonymised.com>:
Dear Marco,
some sample date.I would start from the info below:
- geoserver version
- SLD used
Simone GiannecchiniGeoServer Professional Services from the experts! Visit
http://goo.gl/NWWaa2 for more information.Ing. Simone Giannecchini
@simogeo
Founder/DirectorGeoSolutions S.A.S.
mob: +39 333 8128928http://www.geo-solutions.it
D.Lgs. 196/2003.The information in this message and/or attachments, is intended solely
privacy act (Legislative Decree June, 30 2003, no.196 - Italy’s New
transmission, viruses, etc.On Fri, May 15, 2015 at 10:19 AM, Marco Colasurdo <m.colasu86@anonymised.com> wrote:
band.
Best regards,
Marco
http://ad.doubleclick.net/ddm/clk/290420510;117567292;y
SLD used is:
Size is 831, 698
GEOGCS[“ETRS89”,
Metadata:
AREA_OR_POINT=Area
INTERLEAVE=PIXEL
Corner Coordinates:
Min=0.000 Max=0.950
NoData Value=-9999
Metadata:
NoData Value=-9999
Metadata:
NoData Value=-9999
Metadata:
If you need more informations, I’m at your disposal
Thank you,
Marco
From: Simone Giannecchini <simone.giannecchini@anonymised.com>
Date: 2015-05-18 12:08 GMT+02:00
To: Marco Colasurdo <m.colasu86@anonymised.com>
Cc: geoserver-users <geoserver-users@lists.sourceforge.net>
Dear Marco,
some sample date.
- geoserver version
- SLD used
@simogeo
I’m using GeoServer 2.6.0, and I’ve correctly published a 3-band raster, on which I have applied a style with coninuous >>values to view only the first band.
The problem is that when I open the Layer Preview, I see the raster with only one color, but zooming I’m able to see the >>correct style with all colors that I’ve applied.
Best regards,
Marco
