On Thu, Mar 3, 2016 at 12:17 PM, Chris Buckmaster <chris.buckmaster@anonymised.com> wrote:
Hi
I am trying to enable access to the MrSID and ECW raster data stores and have been following the article here (http://docs.geoserver.org/2.5.x/en/user/data/raster/gdal.html) to try and add these additional raster data stores but they do not seem to be showing up.
I am on a 64 bit Windows Server 2008 R2 Standard operating system and have followed the instructions I think exactly. I did notice that the tutorial mentions ImageIO-Ext 1.1.10 but the GDAL plugin for version 2.5 seems to be using ImageIO-Ext 1.1.8 – I don’t know if that makes any difference?
Basically 1.1.10 and 1.1.8 use same GDAL version so that shouldn’t make any difference.
I would take a look to this page which contains a bit more details (just be aware that you still need to use the versions referred by the previous document):
http://docs.geoserver.org/latest/en/user/data/raster/gdal.html
I am also running Geoserver as a windows service and have restarted the service, do I need to restart anything else to get this to work?
We have noticed a couple of months ago that when you install GeoServer as a windows service, it will install the 32 bit version.
http://docs.geoserver.org/latest/en/user/data/raster/gdal.html#note-on-running-geoserver-as-a-service-on-windows
The devs reported that installing it as a service is usually made for demo purposes or quick tests, whilst when need to install it on a 64 bit machine for production, users should use a different approach (as an instance setting up a Tomcat container and drop the war there).
Long story short, you are running a 32 bit service on a 64 bit machine so you will probably notice errors in loading GDAL native libs like this:
Can’t load IA 32-bit .dll on a AMD 64-bit platform
Regarding downloading Microsoft Visual C++ Redistributables, do I need Visual Studio installed on my system to allow these libraries to work;
No need to install the full Visual Studio. Redistributables will be enough.
I have downloaded the MSVC2008 64 bit version as I am using Windows Server 2008, is this correct?
I don’t think there is a 1:1 strict relation.
Sorry for the many questions, just want to get it working!
Thanks, Chris
Daniele
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now!
http://pubads.g.doubleclick.net/gampad/clk?id=272487151&iu=/4140
Geoserver-users mailing list
Ing. Daniele Romagnoli
Senior Software Engineer
Via di Montramito 3/A
