Thank you! Deleting the featureType allowed me to create again ok.
Sent: Tuesday, April 2, 2024 8:47 PM
To: Phil Scadden <P.Scadden@…1389…>
Subject: Re: [Geoserver-users] Problems recreating a layer after a deletion
CAUTION: This email originated from outside of the organization. Do not click links or open attachments unless you recognize the sender and know the content is safe:
Gut feeling, you might be ignoring the relationship between featuretype and layer. While they are separate resources,
you have to delete both of them when performing a remove.
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
On Mon, Apr 1, 2024 at 7:57 AM Phil Scadden <P.Scadden@…1389…> wrote:
I created a layer from a datastore with:
curl -u user:passwd -X POST -H “Content-type: text/xml” -d “MylayermylayerMy Layer wks:myStyleEPSG:2193” https://myserver/rest/workspaces/wks/datastores/wks-zl/featuretypes
However, the structure in the postgis datastore so I deleted with:
curl -u user:passwd -X POST -H “Content-type: text/xml” https://myserver/rest/layers/wks:Mylayer
Doesn’t show up. However, when I tried recreate with exactly the same POST, I get:
Resource named ‘Mylayer’ already exists in store: ‘wks-zl’
Clearly, I did delete wrong, but how do I republish via REST?
Ngā mihi, Nā Phil Scadden (he/him)
Te Raraunga me te Tātaritanga Mokowā Aronuku (Geospatial Data and Analysis)
GNS Science Te Pῡ Ao
13A Alma St, Renwick, 7204
New Zealand Ph +64 27 3463185
“Whāia te iti kahurangi ki te tūohu koe me he maunga teitei”
Notice: This email and any attachments are confidential and may not be used, published or redistributed without the prior written consent of the Institute of Geological and Nuclear Sciences Limited (GNS Science). If received in error please destroy and immediately notify GNS Science. Do not copy or disclose the contents.
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
