I am working on SLDs. I tried the GeoEXT in combination with the latest version of GeoServer and REST-plugin but no layers were found in the list. It is possible that GeoEXT Styler does not work with the latest version of GeoServer (?) because i had no problems with GeoEXT Styler with older versions of GeoServer.
Furthermore, an exception was thrown after validating a large SLD. Here the first five lines:
java.lang.IllegalStateException: Form too large221608>200000 at org.mortbay.jetty.Request.extractParameters(Request.java:1386) at org.mortbay.jetty.Request.getParameterValues(Request.java:773) at javax.servlet.ServletRequestWrapper.getParameterValues(ServletRequestWrapper.java:200) at org.acegisecurity.wrapper.SavedRequestAwareWrapper.getParameter(SavedRequestAwareWrapper.java:325)
Is there any configuration file where i can regulate the maximum size of SLDs or do i have to change the source code?
Friedrich
On Tue, Sep 28, 2010 at 5:47 AM, Bayer, Friedrich <friedrich.bayer@anonymised.com> wrote:
Do you have the restconfig extension installed in geoserver?
You are validating it from the geoserver ui? Not sure if this is a limitation or not… can you share your SLD?
Friedrich
Start uncovering the many advantages of virtual appliances
and start using them to simplify application deployment and
accelerate your shift to cloud computing.
http://p.sf.net/sfu/novell-sfdev2dev
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
