[Geoserver-users] Problems with Geotiff Coverage
I have some problems in visualizing a Geotiff coverage using WMS Post (GeoServer 1.5.3):
The raster is correctly returned using a get request, like this one:
http://localhost:8080/geoserver/wms?bbox=2318600.0,4852200.0,2325920.0,4858400.0&styles=&Format=image/png&request=GetMap&layers=topp:test&width=800&height=635&srs=EPSG:3004#
using a WMS POST request like the following one, I get a blank image:
<GetMap xmlns:xlink="http://www.w3.org/1999/xlink&quot; xmlns:gml="http://www.opengis.net/gml&quot; service="WMS" xmlns:topp="http://www.openplans.org/topp&quot; version="1.3.0">
    <StyledLayerDescriptor version ="1.0.0">
        <NamedLayer>
            <Name>topp:test</Name>
            <UserStyle>
                <Name>test</Name>
                <FeatureTypeStyle>
                    <FeatureTypeName>test</FeatureTypeName>
                    <Rule>
                        <Name>test</Name>
                        <RasterSymbolizer>
                            <Opacity>1</Opacity>
                        </RasterSymbolizer>
                    </Rule>
                </FeatureTypeStyle>
            </UserStyle>
        </NamedLayer> </StyledLayerDescriptor>
    <BoundingBox srsName="http://www.opengis.net/gml/srs/epsg.xml#3004&quot;&gt;
        <gml:coord>
            <gml:X>2318600.0</gml:X>
            <gml:Y>4852200.0</gml:Y>
        </gml:coord>
        <gml:coord>
            <gml:X>2325920.0</gml:X>
            <gml:Y>4858400.0</gml:Y>
        </gml:coord>
    </BoundingBox>
    <Output>
        <Format>image/png</Format>
        <Transparent>true</Transparent>
        <Size>
            <Width>800</Width>
            <Height>635</Height>
        </Size>
    </Output>
    <Exceptions>XML</Exceptions>
</GetMap>
EPSG:3004 is the native CRS for the Geotiff file. Is there anything wrong in my request or are there any difference from WMS get and post using coverages?
Mauro Bartolomeoli
Hi Mauro,
try changing your POST request as follows:
EPSG:3004
(GeoServer 1.5.3):
topp:test
test
test
test
1
gml:coord
gml:X2318600.0</gml:X>
gml:Y 4852200.0</gml:Y>
</gml:coord>
gml:coord
gml:X2325920.0</gml:X>
gml:Y4858400.0</gml:Y>
</gml:coord>
image/png
true
800
635
XML
using coverages?
Mauro Bartolomeoli
Geoserver-users mailing list
Eng. Alessio Fabiani
Vice-President /CTO GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 349 8227000
Sorry my mistake … the previous is valid only for WCS POST requests … I will inspect deeper why WMS one doesn’t work!
On 9/3/07, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
Hi Mauro,
EPSG:3004
(GeoServer 1.5.3):
topp:test
test
test
test
1
gml:coord
gml:X 2318600.0</gml:X>
</gml:coord>
gml:coord
</gml:coord>
image/png
true
800
635
XML
using coverages?
Mauro Bartolomeoli
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
The problem should be on the UserStyle definition … try first commenting out the UserStyle node and see what happens. It should render your image using the default style associated to the coverage.
Hi Mauro,
EPSG:3004
(GeoServer 1.5.3):
topp:test
test
test
test
1
gml:coord
</gml:coord>
gml:coord
</gml:coord>
image/png
true
800
635
XML
using coverages?
Mauro Bartolomeoli
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
It seems that the problem is in the tag. If I specify Feature (as in the raster.sld style) everithing is ok, if instead I use test, as I usually do with other features, I get a blank result. Is this the correct behaviour, or is there any bug causing this?
Mauro
Hi Mauro,
EPSG:3004
(GeoServer 1.5.3):
topp:test
test
test
test
1
gml:coord
</gml:coord>
gml:coord
</gml:coord>
image/png
true
800
635
XML
using coverages?
Mauro Bartolomeoli
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
On a WFS GetFeature call, is it possible to return all attributes of a feature except the geometry? I want to fetch a features informational attributes but I'm not interested in the geometry.
Thanks, David Robison
David R Robison
Open Roads Consulting, Inc.
708 S. Battlefield Blvd., Chesapeake, VA 23322
phone: (757) 546-3401
e-mail: drrobison@anonymised.com
web: http://openroadsconsulting.com
blog: http://therobe.blogspot.com
book: http://www.xulonpress.com/book_detail.php?id=2579
I don't know if there's a way to say "give me all fields EXCEPT the_geom"
but you can ask for only the fields you want using 'PropertyName=', like
this:
/wfs?request=GetFeature&typeName=myFeature&PropertyName=field1,field2,field7
etc
Stephen Crawford
Center for Environmental Informatics
The Pennsylvania State University
-----Original Message-----
From: geoserver-users-bounces@lists.sourceforge.net
[mailto:geoserver-users-bounces@lists.sourceforge.net] On Behalf Of David R
Robison
Sent: Thursday, September 13, 2007 10:00 AM
To: geoserver users
Subject: [Geoserver-users] WFS GetFeature returning attributes but
notgeometry?
David R Robison
This SF.net email is sponsored by: Microsoft Defy all challenges.
Microsoft(R) Visual Studio 2005.
Is it possible to construct a WFS GetFeature call that would return a feature that contains a point? Thanks, David Robison
David R Robison
It seems the question is - which feature (if any) does my point fall inside?
I think this sample WFS request answers it:
http://lyceum.massgis.state.ma.us/wiki/doku.php?id=wfs:contains&s=wfs
Given a point and a datalayer (here towns) it returns the town that the
point falls in.
(The point is in the same projection as the datalayer).
David R Robison
Defy all challenges. Microsoft(R) Visual Studio 2005.
View this message in context: http://www.nabble.com/Problems-with-Geotiff-Coverage-tf4360977.html#a12656438
