[Geoserver-users] Problems with shapefile geometry with 3/4 dimension (WFS/WPS only)
I’m experiencing problems querying with WFS’s GetFeature layers based on shapefile with geometry with more than 2 dimensions.
My test environment:
  • Windows 10, Tomcat 9.0.54, Java jdk-11.0.12.7-hotspot (Adoptium by Eclipse Foundation)
My test data
  • polygonal shapefile elaborated with ogr2ogr to produce 2D, 3D (xyz & xym) and 4D geometry (xyzm). The original shapefile was a 4D geometry coming from ESRI’s applications.
  • ogr2ogr -dim XYZM OrigEdificiXYZM.shp EdificiXYZM.shp
  • ogr2ogr -dim XYZ OrigEdificiXYZM.shp EdificiXYZ.shp
  • ogr2ogr -dim XYM OrigEdificiXYZM.shp EdificiXYM.shp
  • ogr2ogr -dim XY OrigEdificiXYZM.shp EdificiXY.shp
My test query:
http://localhost:8089/geoserver/wfs?service=WFS&version=2.0.0&request=GetFeature&typeName=common:EdificiXYM&bbox=493318, 5048991, 493319, 5048992&srsName=EPSG:32632
I launched with PostMan the WFS GetFeature with a bbox filter and I got this results on different version of GeoServer:
3D (XYZ/XYM)
4D (XYZM)
2D (XY)
2.20.0
O
O
ü
2.19.3
O
O
ü
2.18.5
O
O
ü
2.17.5
O
O
ü
2.16.5
ü
ü
ü
2.16.0
ü
ü
ü
The XYZM and XYZ test cases give the same error "Invalid ordinate index: 3."
Excerpt from logfile:
java.lang.IllegalArgumentException: Invalid ordinate index: 3
at org.locationtech.jts.geom.Coordinate.setM(Coordinate.java:218)
at org.locationtech.jts.geom.impl.PackedCoordinateSequence.getCoordinate(PackedCoordinateSequence.java:116)
at org.locationtech.jts.operation.predicate.RectangleIntersectsSegmentVisitor.checkIntersectionWithSegments(RectangleIntersects.java:327)
at org.locationtech.jts.operation.predicate.RectangleIntersectsSegmentVisitor.checkIntersectionWithLineStrings(RectangleIntersects.java:317)
at org.locationtech.jts.operation.predicate.RectangleIntersectsSegmentVisitor.visit(RectangleIntersects.java:310)
at org.locationtech.jts.geom.util.ShortCircuitedGeometryVisitor.applyTo(ShortCircuitedGeometryVisitor.java:35)
at org.locationtech.jts.operation.predicate.RectangleIntersects.intersects(RectangleIntersects.java:110)
at org.locationtech.jts.operation.predicate.RectangleIntersects.intersects(RectangleIntersects.java:58)
at org.locationtech.jts.geom.Geometry.intersects(Geometry.java:754)
at org.geotools.filter.spatial.BBOXImpl.basicEvaluate(BBOXImpl.java:118)
at org.geotools.filter.spatial.BBOXImpl.evaluateInternal(BBOXImpl.java:107)
The XYM test case gives an "Index 69 out of bounds for length 69"
java.lang.ArrayIndexOutOfBoundsException: Index 69 out of bounds for length 69
at org.geotools.geometry.jts.LiteCoordinateSequence.setOrdinate(LiteCoordinateSequence.java:224)
at org.geotools.data.shapefile.shp.PolygonHandler.readCoordinates(PolygonHandler.java:315)
at org.geotools.data.shapefile.shp.PolygonHandler.read(PolygonHandler.java:142)
at org.geotools.data.shapefile.shp.ShapefileReader$Record.shape(ShapefileReader.java:114)
at org.geotools.data.shapefile.ShapefileFeatureReader.getGeometry(ShapefileFeatureReader.java:239)
at org.geotools.data.shapefile.IndexedShapefileFeatureReader.hasNext(IndexedShapefileFeatureReader.java:86)
at org.geotools.data.ReTypeFeatureReader.hasNext(ReTypeFeatureReader.java:191)
at org.geotools.data.MaxFeatureReader.hasNext(MaxFeatureReader.java:82)
WMS GetMap works fine with all types of geometries.
It’s clearly a GeoTools error and though I found information about this having been already solved (https://osgeo-org.atlassian.net/browse/GEOT-6599) I’m still having issues.
Stefano
Someone else was mentioning issues with LiteCoordinateSequence, I have not had an opportunity to look at it yet.
Jody
Jody Garnett
This has been going on for a while, snowballing… a number of different developers
have been providing patches during the last few years, each time adding tests, and each
time apparently fixing something but breaking something else.
It seems we did not have enough tests covering M and Z, and we still do not,
despite the fair number of test methods in here:
https://github.com/geotools/geotools/blob/main/modules/plugin/shapefile/src/test/java/org/geotools/data/shapefile/shp/ZMHandlersTest.java
Please open a ticket, attach a sample shapefile along with requests that make the system fail.
Hopefully it will be picked up during one of the future bug fix code sprints.
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 333 8128928
Thank you Andrea,
I’ve just created a ticket GEOS-10290 attaching data and WFS requests.
Stefano
On Thu, Oct 28, 2021 at 9:48 AM Andrea Aime <andrea.aime@anonymised.com> wrote:
On Wed, Oct 27, 2021 at 10:16 AM stefano pezzi <stefanopezzi@anonymised.com> wrote:
My test data
My test query:
3D (XYZ/XYM)
4D (XYZM)
2D (XY)
2.20.0
O
O
ü
2.19.3
O
O
ü
2.18.5
O
O
ü
2.17.5
O
O
ü
2.16.5
ü
ü
ü
2.16.0
ü
ü
ü
Stefano
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
