[Geoserver-users] Publishing GeoTiffs - ColorPalette with Alpha
I want to publish rasterdata (Geotiffs) with GeoServer. The resulting image
from WMS is shown in Grayscale, but actually it is an RGB-Image.
gdalinfo:
P:\OSGeo4W\bin>P:\OSGeo4W\bin\gdalinfo Q:\data\tif\pic.tif
Driver: GTiff/GeoTIFF
Files: Q:\data\tif\pic.tif
Size is 4523, 4522
Coordinate System is:
LOCAL_CS["DHDN / 3-degree Gauss-Kruger zone 3",
    GEOGCS["DHDN",
        DATUM["unknown",
            SPHEROID["unretrievable - using WGS84",6378137,298.257223563]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433]],
    AUTHORITY["EPSG","31467"],
    UNIT["metre",1]]
Origin = (3532474.929505631800000,5367000.280343170300000)
Pixel Size = (0.333485342299112,-0.333485342299112)
Metadata:
  AREA_OR_POINT=Area
  TIFFTAG_DATETIME=2012/05/08 11:38:04
  TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
  TIFFTAG_SOFTWARE=WGEO 5.0 WGEO BASIS
  TIFFTAG_XRESOLUTION=200
  TIFFTAG_YRESOLUTION=200
Image Structure Metadata:
  COMPRESSION=DEFLATE
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( 3532474.930, 5367000.280)
Lower Left ( 3532474.930, 5365492.260)
Upper Right ( 3533983.284, 5367000.280)
Lower Right ( 3533983.284, 5365492.260)
Center ( 3533229.107, 5366246.270)
Band 1 Block=256x256 Type=Byte, ColorInterp=Palette
  Overviews: 2262x2261, 1131x1131, 566x566
  Mask Flags: PER_DATASET ALPHA
  Overviews of mask band: 2262x2261, 1131x1131, 566x566
  Color Table (RGB with 256 entries)
    0: 0,0,0,255
    1: 128,0,0,255
    2: 0,128,0,255
    3: 128,128,0,255
    4: 0,0,128,255
  253: 255,0,255,255
  254: 0,255,255,255
  255: 255,255,255,255
Band 2 Block=256x256 Type=Byte, ColorInterp=Alpha
I think the problem is the Alpha-Channel. Without this Channel, the
resulting image/colors are correct.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Publishing-GeoTiffs-ColorPalette-with-Alpha-tp5128601.html
What style have you configured the WMS layer with? Can you cut and paste the SLD contents?
Jody Garnett
gdalinfo:
Size is 4523, 4522
LOCAL_CS[“DHDN / 3-degree Gauss-Kruger zone 3”,
GEOGCS[“DHDN”,
DATUM[“unknown”,
SPHEROID[“unretrievable - using WGS84”,6378137,298.257223563]],
PRIMEM[“Greenwich”,0],
UNIT[“degree”,0.0174532925199433]],
AUTHORITY[“EPSG”,“31467”],
UNIT[“metre”,1]]
Metadata:
AREA_OR_POINT=Area
COMPRESSION=DEFLATE
INTERLEAVE=PIXEL
Corner Coordinates:
0: 0,0,0,255
1: 128,0,0,255
2: 0,128,0,255
3: 128,128,0,255
4: 0,0,128,255
253: 255,0,255,255
254: 0,255,255,255
Learn Graph Databases - Download FREE O’Reilly Book
“Graph Databases” is the definitive new guide to graph databases and their
applications. Written by three acclaimed leaders in the field,
this first edition is now available. Download your free book today!
http://p.sf.net/sfu/13534_NeoTech
Geoserver-users mailing list
Ciao,
please, find my comments inline below....
Simone Giannecchini
Meet us at GEO Business 2014! in London! Visit Visit GeoSolutions at GEO Business 2014 in London! - GeoSolutions
for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
gdalinfo:
Size is 4523, 4522
    GEOGCS["DHDN",
        DATUM["unknown",
    UNIT["metre",1]]
Metadata:
  AREA_OR_POINT=Area
  COMPRESSION=DEFLATE
  INTERLEAVE=PIXEL
Corner Coordinates:
    0: 0,0,0,255
    1: 128,0,0,255
    2: 0,128,0,255
    3: 128,128,0,255
    4: 0,0,128,255
  253: 255,0,255,255
  254: 0,255,255,255
You are right, I believe we don't (currently) support this kind of
GeoTiff in GeoServer.
I would probably try to select the first band and see what happens,
going by memory I am not sure we should retain the colormap atatched
to it.
That said, could you share a sample of such imagery for testing?
Learn Graph Databases - Download FREE O'Reilly Book
"Graph Databases" is the definitive new guide to graph databases and their
