[Geoserver-users] Python WPS scripting broken in Geoserver 2.3.x
It is for sure good to test with OpenJDK and Oracle 1.7 JDK, but Geoserver has some known issues with both of them and Oracle 1.6 jre is the officially supported version. Probably it would be more pleasure to test with that first.
-Jukka Rahkonen-
Tom van Tilburg wrote:
Yes, I can see the WPS among the WCS/WFS/WMS services in the left of the menu and my handcrafted python process that I have put in ./data/scripts/wps/ is displayed in the list of WPS processes (py:mybuffer)
By the way, I have OpenJDK installed.
At the moment I’m testing with Oracle 1.7 JDK and that gives me a
javax.script.ScriptException: ImportError: cannot import name process in /var/data/tomcat7/webapps/geoserver/data/scripts/wps/mybuffer.py at line number 1
It’s a slightly different server though with Oracle JDK, so I’m testing some more.
Chrs, Tom
On 27-3-2013 14:53, Justin Deoliveira wrote:
Hi Tom,
Can you confirm that you have the wps extension installed in the 2.3 version?
-Justin
On Tue, Mar 26, 2013 at 9:57 AM, Tom van Tilburg <tom.van.tilburg@anonymised.com> wrote:
Hi Guys,
Thank you very much for the new geoserver release. Lot’s of great
functionality.
One regression I found so far:
The python scripting seems to be broken in 2.3.x
Steps to reproduce:
Install:
http://gridlock.opengeo.org/geoserver/2.3.x/geoserver-2.3.x-latest-war.zip
http://gridlock.opengeo.org/geoserver/2.3.x/ext-latest/geoserver-2.3-SNAPSHOT-wps-plugin.zip
http://gridlock.opengeo.org/geoserver/2.3.x/community-latest/geoserver-2.3-SNAPSHOT-python-plugin.zip
add buffer WPS according to manual in ./scripts/wps :
http://docs.geoserver.org/stable/en/user/community/scripting/hooks.html
and try to request the WPS service.
Geoserver complaints about a NoClassDefFound: SimpleProcessingCollection
Exactly the same steps with 2.2 give good results.
Tom
Own the Future-Intel® Level Up Game Demo Contest 2013
Rise to greatness in Intel’s independent game demo contest.
Compete for recognition, cash, and the chance to get your game
on Steam. $5K grand prize plus 10 genre and skill prizes.
Submit your demo by 6/6/13. http://p.sf.net/sfu/intel_levelupd2d
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
I just installed SUN JAVA 1.6 JRE, but the problem persists. Here's a snippet from the error log:
2013-03-27 15:53:58,962 WARN [imagemosaic.ImageMosaicFormat] - java.lang.RuntimeException: java.io.IOException: javax.script.ScriptException: java.lang.NoClassDefFoundError: java.lang.NoClassDefFoundError: org/geotools/process/feature/gs/SimpleProcessingCollection in /var/data/tomcat7/webapps/geoserver/data/scripts/wps/mybuffer.py at line number 1
org.geotools.data.DataSourceException: java.lang.RuntimeException: java.io.IOException: javax.script.ScriptException: java.lang.NoClassDefFoundError: java.lang.NoClassDefFoundError: org/geotools/process/feature/gs/SimpleProcessingCollection in /var/data/tomcat7/webapps/geoserver/data/scripts/wps/mybuffer.py at line number 1
Line 1 in mybuffer.py reads:
     from geoserver.wps import process
Java info:
Sun Microsystems Inc.: 1.6.0_43 (Java HotSpot(TM) 64-Bit Server VM)
(using Tomcat7)
As far as I understand the imagemosaic has nothing to do with this, the exception shows up a couple of times at different points in the startup of geoserver on Tomcat7.
Chrs,
  Tom
On 27-3-2013 15:11, Rahkonen Jukka wrote:
-Jukka Rahkonen-
At the moment I'm testing with Oracle 1.7 JDK and that gives me a
It's a slightly different server though with Oracle JDK, so I'm testing some more.
Chrs, Tom
Hi Tom
We were having problems with the python scripting hook too. It turned out to be jar compatibility. I’m not sure if it’s the same problem but here’s our error and how we solved it.
Error:
Caused by: java.io.IOException: javax.script.ScriptException: ImportError: No module named types in /h/data/gis/geoserver/external/scripts/wps/buffer.py at line number 1
Solution:
Install geoserver pyhton and javascript scripting hooks
<initial assumptions - jboss7, java7, geoserver 2.2.4)
  1. undeploy geoserver
  2. download geoserver python and javascript scripting extensions from http://gridlock.opengeo.org/geoserver/2.2.x/community-latest/
  3. copy both zip files into directory /geoserver.war/WEB-INF/lib
  4. extract both zip files (if prompted to replace, select ‘N’)
  5. in WEB-INF/lib, delete jython-2.5.2.jar
  6. access jython download page (http://www.jython.org/downloads.html). Download jython 2.7b1 standalone
  7. cp jython-standalone-2.7-b1.jar /geoserver.war/WEB-INF/lib
  8. deploy geoserver
  9. create scripting hooks
cd
cd scripts/wps
create buffer.py (code found at http://docs.geoserver.org/latest/en/user/community/scripting/hooks.html)
  1. test python hook
From: Tom van Tilburg [mailto:tom.van.tilburg@anonymised.com]
Sent: Wednesday, March 27, 2013 8:02 AM
To: geoserver-users@anonymised.comrceforge.net
Subject: Re: [Geoserver-users] Python WPS scripting broken in Geoserver 2.3.x
I just installed SUN JAVA 1.6 JRE, but the problem persists. Here’s a snippet from the error log:
Java info:
Sun Microsystems Inc.: 1.6.0_43 (Java HotSpot™ 64-Bit Server VM)
(using Tomcat7)
Chrs,
Tom
-Jukka Rahkonen-
Chrs, Tom
Hi Dominique,
Thanks for this information.
I assume you also have the WPS plugin installed? And did you let the WPS plugin overwrite original JAR files? (I did not)
I tried your solution following the steps (using geoserver 2.3.0 instead) and replacing jython but curiously I ended up having the error you described yourself:
java.lang.RuntimeException: java.io.IOException: javax.script.ScriptException: ImportError: No module named types in /var/data/tomcat7/webapps/geoserver/data/scripts/wps/mybuffer.py at line number 1 at org.geoserver.script.wps.ScriptProcessFactory.getDescription(ScriptProcessFactory.java:112) at org.geoserver.wps.web.WPSRequestBuilderPanel.initProcessView(WPSRequestBuilderPanel.java:250) at org.geoserver.wps.web.WPSRequestBuilderPanel.access$000(WPSRequestBuilderPanel.java:63) at org.geoserver.wps.web.WPSRequestBuilderPanel$5.onUpdate(WPSRequestBuilderPanel.java:225)
Seems it is really a 2.3 problem with jython?
(For the record: I also tried nightly war files with the plugins.)
  Tom
On 27-3-2013 16:51, Bessette-Halsema, Dominique E wrote:
Hi Tom
We were having problems with the python scripting hook too. It turned out to be jar compatibility. I'm not sure if it's the same problem but here's our error and how we solved it.
Error:
Solution:
1) undeploy geoserver
2) download geoserver python and javascript scripting extensions from http://gridlock.opengeo.org/geoserver/2.2.x/community-latest/
3) copy both zip files into directory <jboss deployment dir>/geoserver.war/WEB-INF/lib
4) extract both zip files (if prompted to replace, select 'N')
5) in WEB-INF/lib, delete jython-2.5.2.jar
6) access jython download page (http://www.jython.org/downloads.html). Download jython 2.7b1 standalone
7) cp jython-standalone-2.7-b1.jar <jboss deployment dir>/geoserver.war/WEB-INF/lib
8) deploy geoserver
9) create scripting hooks
cd <geoserver data dir>
cd scripts/wps
10) test python hook
*From:*Tom van Tilburg [mailto:tom.van.tilburg@anonymised.com]
*Sent:* Wednesday, March 27, 2013 8:02 AM
*To:* geoserver-users@lists.sourceforge.net
*Subject:* Re: [Geoserver-users] Python WPS scripting broken in Geoserver 2.3.x
Java info:
(using Tomcat7)
Chrs,
Tom
    -Jukka Rahkonen-
    (py:mybuffer)
    process in
    at line number 1
    testing some more.
    Chrs, Tom
Yes we used the plugin with geoserver 2.2.4 and we did not overwrite the original jars. Our error was due to the jython jar delivered with the geoserver python plugin was based on Java5 and we are using Java7. Maybe yours is a geotools jar missing/mismatch issue?? The jar containing org/geotools/process/feature/gs/SimpleProcessingCollection is the gt-process-feature.jar
Dom
Sent: Thursday, March 28, 2013 3:52 AM
To: Bessette-Halsema, Dominique E
Hi Dominique,
at line number 1 at
at
at
at
Tom
Hi Tom
Error:
Solution:
  8. deploy geoserver
cd
cd scripts/wps
  1. test python hook
Java info:
(using Tomcat7)
Chrs,
Tom
-Jukka Rahkonen-
Chrs, Tom
Tom,
Looks like org.geotools.process.feature.gs in GeoTools 8 was replaced with
org.geotools.process.vector in GeoTools 9.
Try copying gt-process-feature-8-SNAPSHOT.jar from Geoserver 2.2.x to your
Geoserver 2.3 installation. The WPS example should now work.
Ami.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Python-WPS-scripting-broken-in-Geoserver-2-3-x-tp5043036p5043574.html
I think you're right, it should be the jar.
The jar is there however, and I can see it contains the SimpleProcessingCollection method.
I'm a bit stuck on the options, except for going back to 2.2
  Tom
On 28-3-2013 16:48, Bessette-Halsema, Dominique E wrote:
Yes we used the plugin with geoserver 2.2.4 and we did not overwrite the original jars. Our error was due to the jython jar delivered with the geoserver python plugin was based on Java5 and we are using Java7. Maybe yours is a geotools jar missing/mismatch issue?? The jar containing org/geotools/process/feature/gs/SimpleProcessingCollectionis the gt-process-feature.jar
Dom
*Sent:* Thursday, March 28, 2013 3:52 AM
*To:* Bessette-Halsema, Dominique E
*Cc:* geoserver-users@lists.sourceforge.net
Hi Dominique,
        at line number 1 at
        at
        at
        at
Tom
    Hi Tom
    Error:
    Solution:
    standalone
    8) deploy geoserver
    cd scripts/wps
    <mailto:geoserver-users@lists.sourceforge.net>
    Geoserver 2.3.x
    at line number 1
    at line number 1
    Java info:
    (using Tomcat7)
    Chrs,
     Tom
        -Jukka Rahkonen-
        process in
        at line number 1
        Chrs, Tom
Ami, that fixed it.
Thanks so much!
Is any filing of this needed somewhere?
--Tom
On 28-3-2013 17:14, arahav wrote:
Tom,
Ami.
Own the Future-Intel&reg; Level Up Game Demo Contest 2013
Rise to greatness in Intel's independent game demo contest.
Thanks for digging in on this everyone. I have tracked the problem to an issue in the upstream geoscript-py dependency and created this issue.
https://jira.codehaus.org/browse/GEOS-5742
Should be a straight forward fix, wil update shortly.
On Fri, Mar 29, 2013 at 5:07 AM, Tom van Tilburg <tom.van.tilburg@anonymised.com> wrote:
Ami, that fixed it.
Thanks so much!
–Tom
Tom,
Ami.
Own the Future-Intel(R) Level Up Game Demo Contest 2013
Rise to greatness in Intel’s independent game demo contest. Compete
for recognition, cash, and the chance to get your game on Steam.
$5K grand prize plus 10 genre and skill prizes. Submit your demo
by 6/6/13. http://altfarm.mediaplex.com/ad/ck/12124-176961-30367-2
Justin Deoliveira
