[Geoserver-users] Q: enforce bbox/extent in geoserver wms
Thanks. Still also a WMS is required. I found an option that worked: As
the feature data is in PostGIS, I defined a
new feature type as a PostGIS View using a SELECT with a bbox query. best,
--Just
I believe the WMS specs demand it.
If you have a client that can do tiling you can use the built-in
GeoWebCache. It will just serve the same, transparent PNG for anything
falling outside the bounds.
-Arne
Just van den Broecke wrote:
Is it possible to enforce viewing a particular (bbox) extent within a GS
WMS Layer ?
That is: I have feature data covering the entire Netherlands, but for
this
layer I only need to serve a particular (inner) bbox without showing
data
outside of that bbox. I can set a bbox in the FeatureType Editor, but GS
always will serve the according to the extent of the dataset not the
(inner) bbox. (btw UMN MapServer will do the same). thanks,
http://www.justobjects.nl
Register Now & Save for Velocity, the Web Performance & Operations
Conference from O'Reilly Media. Velocity features a full day of
expert-led, hands-on workshops and two days of sessions from industry
leaders in dedicated Performance & Operations tracks. Use code vel09scf
and Save an extra 15% before 5/3. http://p.sf.net/sfu/velocityconf
Geoserver-users mailing list
Arne Kepp
OpenGeo - http://opengeo.org
Expert service straight from the developers
Just
Just Objects B.V. - http://www.justobjects.nl
