[Geoserver-users] Question about GeoTiffs
Hi -
     I have some .tifs with associated .prj and .tfw loaded into Geoserver 2.2-snapshot. If I try downloading one of these layers as a GeoTiff, I get a file much, much smaller than the original TIFF. Not only that, when I take that file, put it in Geoserver's data dir, and attempt to load it as a GeoTiff, I get the error
             Could not list layers for this store, an error occurred retrieving them: Argument "value" should not be null
     Is it naive to expect that a layer downloaded as a GeoTiff could be loaded into Geoserver as a GeoTiff?
Garey Mills
Library Systems Office
UC Berkeley
On Thu, Jun 7, 2012 at 1:41 AM, Garey Mills <gmills@anonymised.com> wrote:
Hi -
I have some \.tifs with associated \.prj and \.tfw loaded into
Nope, it's not, but there are two issues:
- ESRI calls "GeoTiff" stuff that is not actually a Geotiff according to the
  standard (http://trac.osgeo.org/geotiff/), typically a world + image file
  (not your case I understand)
- GeoServer is unable to read GeoTiffs that is georeferenced by
  a custom CRS (not an official EPSG code)
Both issues could be solved by some coding, the first by being lenient
and look for the ancilliary files if the georeferencing is not present
in the tif file, the second by adding support for parsing a custom
CRS.
That said, code does not write itself (at least for the moment!),
contributions welcomed.
To see if your case is the second one can you run gdalinfo and
report back the output?
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
mob: +39 339 8844549
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
Hi Mr geowolf,
Thanks for your replay and I read your answer to "question about geotiffs".I
create geotiff image using custom SRS system but that SRS has EPSG code.But
in arcmap i can't give EPSG code.
If so what is correct method to create geotiff image,Is there any tool?
"Both issues could be solved by some coding, the first by being lenient
CRS. " This is from your answer in above question.
I am new to this sort of thing and I can't understand above thing.Pls give
me some little bit information
Thanks
View this message in context: http://osgeo-org.1560.n6.nabble.com/Question-about-GeoTiffs-tp4979612p4979765.html
On Thu, Jun 7, 2012 at 5:04 PM, sacprasanna <sacprasanna@anonymised.com> wrote:
Hi Mr geowolf,
I'm not familiar with ESRI tools, can't help you there.
Ah, it just means some developer has to write the code to support
geotiffs with custom crs and/or external georeferencing via
world files and aux files.
The code is going to get written if someone (you for example) does it
and donates
it to the community.
As an alternative, if you don't have development capabilities in house,
you can contract out such development to one of the companies providing
commercial support for GeoServer:
http://geoserver.org/display/GEOS/Commercial+Support
Ing. Andrea Aime
Tech lead
Hi Andrea
You posted that:
"- GeoServer is unable to read GeoTiffs that is georeferenced by
  a custom CRS (not an official EPSG code)"
on Geoserver blog
http://blog.geoserver.org/2012/09/21/geoserver-2-2-released/ is written
that now:
"Better support for un-referenced data with the new EPSG:40400 code that
identifies a coordinate system made up of a generic 2D Cartesian plane"
and what if I have Geotiffs based on some local projection for one of
Polands cities (I don't have WKT or PRJ for this projection) and I want to
get that geotiffs serve by Geoserver WMS. How to do that ?
View this message in context: http://osgeo-org.1560.n6.nabble.com/Question-about-GeoTiffs-tp4979612p5008044.html
