[Geoserver-users] Question about making a WFS request to return features with a subset of the available fields
Hi everyone,
I have what I think should be a simple problem, but I am having trouble locating examples of this in the documentation.
I would like to make a WFS request which returns a set of features and a subset of those features attributes. I know that this can be accomplished using the propertyName parameter of a WFS request if the field names are known and specified. I would like to specify the fields names by instead passing a wild card "*something".
Is this a possibility?
Many thanks for any advice.
Kytt
Kytt MacManus
Geographic Information Specialist
CIESIN
Earth Institute
Columbia University
Adjunct Lecturer
School of International and Public Affairs
Columbia University
P.O. Box 1000
61 Route 9W
Palisades, NY 10964
845-365-8939 (V)
845-365-8922 (F)
www.ciesin.columbia.edu
On Tue, Jan 6, 2015 at 4:18 AM, Kytt MacManus <kmacmanu@anonymised.com>
wrote:
Hi everyone,
It's not part of the WFS specification, nor supported by GeoServer as an
extension,
but I guess you could build a WPS process that does the job for you,
wrapping the standard WFS request as its input
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thanks for the response Andrea.
Perhaps the best option is to describe the service and parse the response to produce the list of desired attributes.
Kind regards,
Kytt
On 1/8/2015 6:06 AM, Andrea Aime wrote:
On Tue, Jan 6, 2015 at 4:18 AM, Kytt MacManus <kmacmanu@anonymised.com <mailto:kmacmanu@anonymised.com>> wrote:
    Hi everyone,
    trouble
    features and
    fields
It's not part of the WFS specification, nor supported by GeoServer as an extension,
but I guess you could build a WPS process that does the job for you, wrapping the standard WFS request as its input
Ing. Andrea Aime
@geowolf
Technical Lead
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
Kytt MacManus
CIESIN
Earth Institute
Columbia University
Adjunct Lecturer
Columbia University
P.O. Box 1000
61 Route 9W
Palisades, NY 10964
845-365-8939 (V)
845-365-8922 (F)
On Thu, Jan 8, 2015 at 5:32 PM, Kytt MacManus <kmacmanu@anonymised.com>
That's indeed how WFS is supposed to be used
Ing. Andrea Aime
@geowolf
Technical Lead
