Wow. Fast as always ![]()
I didn't think to search in geotools Jira too, next time I'll remember to.
I'm using 1.5.0 but I see you fixed the bug in 1.5.4 so there's no point to install the 1.5.3. I'll wait for your next release.
Thank you for your reliable support.
Fabio
-----Messaggio originale-----
Da: Andrea Aime [mailto:aaime@anonymised.com]
Inviato: lunedì 8 ottobre 2007 9.20
A: Fabio Da Soghe
Cc: 'geoserver users'
Oggetto: Re: [Geoserver-users] BUFFER vendor option
malfunctioning when rendering coverages?Fabio Da Soghe ha scritto:
> Hello list.
> I'm using Geoserver 1.5.0 and I have some coverage along
with vector feature types.
> I set the vendor option BUFFER to 10 because I have some
points simbolized with text that gets cutted for the tiled
output (i'm using OpenLayers on the client).
> I see there's a problem with my coverage: they are now
rendered badly, as if the tiles' borders are computed wrong.
I suspect the BUFFER option to be the problem because if I
remove it from my WMS requests, the map is perfect. I've
attached an example of bad map.
> I searched a bit into Jira but I haven't found anything.
I'm alone in this problem?Woops, nasty one, and quite old too, it has been inside GeoServer for
months and nobody noticed.
Well, I think I fixed it (http://jira.codehaus.org/browse/GEOS-1377).
Which version are you using? 1.5.3 or 1.6.0-beta3?Cheers
