Hi.
I have been workin mostly with vectors using WMS, WFS and Openlayers with javascript. Mostly no experience with rasters.
My problem is the following: via geocoding using postal address I can get a coordinate pair. Then I have around 30 rasters (geotiffs) on our Geoserver as separate layers. Does anybody have an idea, how to get a matching raster (coordinate pair from geocoding) from Geoserver, and add it to a map as a layer? Combining those tiffs as one tiff is not a solution (too large).
Thanks, Oiva
On Thu, May 8, 2014 at 11:21 AM, Hakala Oiva (MTT) <oiva.hakala@anonymised.com>wrote:
Hi.
(too large).
How about putting all of them in the same directory and use the image
mosaic plugin? Or are they different in nature (e.g, different color model?)
As an alternative, I guess you can parse the capabilties document, it has
the bbox for each layer, and use that to decide which layer fits.
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thanks
Those rasters share the same srs and color mode. Still don’t know, is it usefull to make an imagemosaic, because don’t know how to call part of it using a coordinate pair? A grid would be much better, but 2m resolution, well, it would be much too heavy.
Oiva
On Thu, May 8, 2014 at 11:21 AM, Hakala Oiva (MTT) <oiva.hakala@anonymised.com> wrote:
Hi.
How about putting all of them in the same directory and use the image mosaic plugin? Or are they different in nature (e.g, different color model?)
As an alternative, I guess you can parse the capabilties document, it has the bbox for each layer, and use that to decide which layer fits.
Ing. Andrea Aime
@geowolf
Technical Lead
Hum…
why does it have to be part of it? GeoSever can effienclty extract only the portion of the mosaic
that is currently in the view, especially if you optimized the rasters (added inner tiles and overviews)
Anyways, your other option is the capabilities parsing one from the client side.
On Thu, May 8, 2014 at 12:01 PM, Hakala Oiva (MTT) <oiva.hakala@anonymised.com83…> wrote:
Thanks
Oiva
Lähettäjä: andrea.aime@anonymised.com [andrea.aime@anonymised.com] käyttäjän Andrea Aime [andrea.aime@anonymised.com] puolesta
Lähetetty: 8. toukokuuta 2014 12:51
Vastaanottaja: Hakala Oiva (MTT)
Kopio: GeoServer Mailing List List
Aihe: Re: [Geoserver-users] Raster question
Ing. Andrea Aime
@geowolf
Technical Lead
Hi.
Ing. Andrea Aime
@geowolf
Technical Lead
You are right of course. No need to call part of the mosaic.
I was thinking, would a layergroup be useful? No extra plugins, no learning curve. Tiffs are not overlapping. It is just a matter of restricting available zoom levels or restricting raster’s visibility depending of a zoom level.
Oiva
Hum…
On Thu, May 8, 2014 at 12:01 PM, Hakala Oiva (MTT) <oiva.hakala@anonymised.com> wrote:
Thanks
Oiva
Ing. Andrea Aime
@geowolf
Technical Lead
Hi.
Ing. Andrea Aime
@geowolf
Technical Lead
On Thu, May 8, 2014 at 12:37 PM, Hakala Oiva (MTT) <oiva.hakala@anonymised.com>wrote:
restricting available zoom levels or restricting raster's visibility
A layer group is not smart enough to drop the rasters it does not need, the
image mosaic is, and it's built-in, no need for extra
plugins.
Just put all of your rasters in a single folder, and point the mosaic store
to the folder, if they are similar enough it should work
Ing. Andrea Aime
@geowolf
Technical Lead
