[Geoserver-users] RD (rijksdriehoeksmeting) coordinate system (EPSG:28992)
For the project I am currently working on I have received historical
maps of Holland. The maps use the RD (Rijksdriehoeksmeting) coordinate
system, also known as EPSG:28992. It is not available in any SRS code
in Geoserver. My questions are:
- Is it possible for me to add the SRS to the list in geoserver and
also to postgis?
- IF ANSWER YES: Does anybody already have the right SRS codes to do
so? Will Geoserver/Postgis be able to convert the SRS to EPSG:4326 so
that I can show the map in Google Earth?
- IF ANSWER NO: Can I convert the RD coordinates to the European
standard ETRS:89 and then have Postgis/Geoserver convert the
coordinates on the fly to EPSG:4326 for Google Earth?
- IF ANSWER TWO TIMES NO: Is the only way for me show the same data in
Google Earth by converting (hard-coded) to EPSG:4326?
Lobo
Checking the list of projections supported by default in GeoServer 1.5.1
and i see EPSG:28992 in the list:
PROJCS["Amersfoort / RD New",
  GEOGCS["Amersfoort",
    DATUM["Amersfoort",
      SPHEROID["Bessel 1841", 6377397.155, 299.1528128,
AUTHORITY["EPSG","7004"]],
      TOWGS84[565.04, 49.91, 465.84, -0.40939438743923684,
-0.35970519561431136, 1.868491000350572, 0.8409828680306614],
      AUTHORITY["EPSG","6289"]],
    PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
    UNIT["degree", 0.017453292519943295],
    AXIS["Geodetic longitude", EAST],
    AXIS["Geodetic latitude", NORTH],
    AUTHORITY["EPSG","4289"]],
  PROJECTION["Oblique Stereographic", AUTHORITY["EPSG","9809"]],
  PARAMETER["central_meridian", 5.387638888888891],
  PARAMETER["latitude_of_origin", 52.15616055555556],
  PARAMETER["scale_factor", 0.9999079],
  PARAMETER["false_easting", 155000.0],
  PARAMETER["false_northing", 463000.0],
  UNIT["m", 1.0],
  AXIS["Easting", EAST],
  AXIS["Northing", NORTH],
  AUTHORITY["EPSG","28992"]]
Lobo wrote:
also to postgis?
Yes, if you have the well known text representation of the crs you can
add it to geoserver here:
http://docs.codehaus.org/display/GEOSDOC/Custom+projection+definition+in+Geoserver+1.5.0+(onwards)
And with postgis i believe you just have to insert the necessary values
into into the spatial_ref_sys table.
Yup, geoserver will convert to EPSG:4326 on the fly when you request
that coordinate reference system.
Lobo
This SF.net email is sponsored by DB2 Express
Download DB2 Express C - the FREE version of DB2 express and take
control of your XML. No limits. Just data. Click to get it now.
http://sourceforge.net/powerbar/db2/
Geoserver-users mailing list
!DSPAM:4007,466f501683702143011171!
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
