Hi Bryce,
we had a similar problem here...At the end what we have done to render
wind arrows was:
1) Creating a Shapefile containing a set of points describing module
and rotation (computed by U and V components) for each arrow (with LAT
LON coordinates associated of course)
2) Building an SLD that drows an arrow with length and color
proportional to the module and the same rotation angle.
We built a software for automating the overall procedure.
The final SLD is quite big but the result is not bad.
Follows a little piece of the resulting SLD. as you can see the main
problem is that because it's not possible to use the shape property
values directly, we had to subdivide modules and directions into
categories. The software we made automatically writes the set of rules
for each direction every module category.
In the example below we have a rule each 2 direction degrees for each
module category.
<StyledLayerDescriptor version="1.0.0"
xsi:schemaLocation="http://www.opengis.net/sld StyledLayerDescriptor.xsd"
xmlns="http://www.opengis.net/sld" xmlns:ogc="http://www.opengis.net/ogc"
xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<NamedLayer>
<Name>Wind Properties</Name>
<UserStyle>
<Name>Default Styler</Name>
<Title>Default Styler</Title>
<Abstract></Abstract>
<FeatureTypeStyle>
<FeatureTypeName>Feature</FeatureTypeName>
* Category 1: module [0.0 - 1.9999]
<Rule>
<ogc:Filter xmlns:gml="http://www.opengis.net/gml">
<ogc:And>
<ogc:PropertyIsBetween>
<ogc:PropertyName>module</ogc:PropertyName>
<ogc:LowerBoundary>
<ogc:Literal>0.0</ogc:Literal>
</ogc:LowerBoundary>
<ogc:UpperBoundary>
<ogc:Literal>1.9999</ogc:Literal>
</ogc:UpperBoundary>
</ogc:PropertyIsBetween>
<ogc:PropertyName>direction</ogc:PropertyName>
<ogc:LowerBoundary>
<ogc:UpperBoundary>
<ogc:Literal>2.9999</ogc:Literal>
</ogc:And>
</ogc:Filter>
<PointSymbolizer>
<Graphic>
<Mark>
<WellKnownName>arrow</WellKnownName>
<Fill>
<CssParameter name="fill">#00FFFF</CssParameter>
</Fill>
</Mark>
<Opacity>
<ogc:Literal>1.0</ogc:Literal>
</Opacity>
<Size>
<ogc:Literal>7.5</ogc:Literal>
</Size>
<Rotation>
</Rotation>
</Graphic>
</PointSymbolizer>
</Rule>
<Rule>
<ogc:And>
<ogc:LowerBoundary>
<ogc:UpperBoundary>
<ogc:LowerBoundary>
<ogc:Literal>3.0</ogc:Literal>
<ogc:UpperBoundary>
<ogc:Literal>4.9999</ogc:Literal>
</ogc:And>
</ogc:Filter>
<PointSymbolizer>
<Graphic>
<Mark>
<Fill>
</Fill>
</Mark>
<Opacity>
</Opacity>
<Size>
</Size>
<Rotation>
<ogc:Literal>3.5</ogc:Literal>
</Rotation>
</Graphic>
</PointSymbolizer>
</Rule>
<Rule>
<ogc:And>
<ogc:LowerBoundary>
<ogc:UpperBoundary>
<ogc:LowerBoundary>
<ogc:Literal>5.0</ogc:Literal>
<ogc:UpperBoundary>
<ogc:Literal>6.9999</ogc:Literal>
</ogc:And>
</ogc:Filter>
<PointSymbolizer>
<Graphic>
<Mark>
<Fill>
</Fill>
</Mark>
<Opacity>
</Opacity>
<Size>
</Size>
<Rotation>
<ogc:Literal>5.5</ogc:Literal>
</Rotation>
</Graphic>
</PointSymbolizer>
</Rule>
* Category 2: module [2.0 - 3.9999]
<Rule>
<ogc:And>
<ogc:LowerBoundary>
<ogc:Literal>2.0</ogc:Literal>
<ogc:UpperBoundary>
<ogc:Literal>3.9999</ogc:Literal>
<ogc:LowerBoundary>
<ogc:UpperBoundary>
</ogc:And>
</ogc:Filter>
<PointSymbolizer>
<Graphic>
<Mark>
<Fill>
<CssParameter name="fill">#17E8FF</CssParameter>
</Fill>
</Mark>
<Opacity>
</Opacity>
<Size>
<ogc:Literal>9.5</ogc:Literal>
</Size>
<Rotation>
</Rotation>
</Graphic>
</PointSymbolizer>
</Rule>
Hope can help.
Alessio.
