I am unable to update the layer configuration of a PostGIS geoserver layer.
I am adding a new column to the existing and published PostGIS table in the first step.
However, the geoserver automatically doesn’t reflect the changes made to the layer. We need to manually do it through the geoserver admin interface using the “Reload feature type” option (image below) or automate it through the geoserver rest API.
The Python code for updating layer configuration through rest-API is given below.
session = requests.Session()
session.auth = (username, password)
layer_url_json = f"{geoserver_url_dL}/workspaces/{workspace_dL}/datastores/{store}/featuretypes/{layer_name}.json"
response1 = session.get(layer_url_json)
layer_info = response1.json() #print(layer_info)
new_column = {
“name”: “type12”,
“type”: “Boolean”, # Set the data type for the new column
“nillable”:True,
“minOccurs”: 0, # Optional: Minimum occurrences
“maxOccurs”: 1 # Optional: Maximum occurrences
layer_info[‘featureType’][‘attributes’][‘attribute’].append(new_column)
response2 = session.put(layer_url_json, headers={‘Content-type’: ‘application/json’},
The above code was working perfectly in geoserver-2.20.0 and the changes to layer configuration are being reflected.
However, I am getting a 500 error for response2 with the text “The CQL source expression for attribute type12 refers to attributes unavailable in the data source: [type12]” in later versions of geoserver like geoserver-2.23, 2.24, 2.25-SNAPSHOT
I tried to verify the PostGIS table and the column is already added to the table, and the rest-api interactions with geoserver 2.23-SNAPSHOT are working fine as i was able to retrieve “layer_info” and also successfully tested adding a new workspace using rest-api in this version.
Unfortunately, I can’t fix this error. Is this my code error specific to the version of the geoserver or is it a geoserver bug?
Thanks for the response. I have tried different methods and nothing works. The only workaround I figured out is that we can set the layer’s “enabled=false” and set it to true every time a column is altered or a new column is created.
However, geoserver is a part of my cloud saas platform. A user can upload vector data and the data is saved into a PostGIS table and then published to geoserver as a layer. The user can share this uploaded data/layer to multiple other users. All the shared users with edit permission can create, delete, duplicate, and rename the columns of this existing layer.
Altering the layers “enabled” every time a user performs column operations might affect the performance.
It is an uncommon solution to let users change the schema of the tables freely. I do not say that it is wrong, but users adding data into tables which are predefined by the administrators is the traditional way and therefore better supported.
Could the OpenStreetMaps data model suit for your use case? That does not have much attribute schema, just tags and values.
-Jukka Rahkonen-
Lähettäjä: Harsha Yegireddi <harsha6772@…84…> Lähetetty: perjantai 3. marraskuuta 2023 8.59 Vastaanottaja: Jody Garnett <jody.garnett@…84…> Kopio:geoserver-users@lists.sourceforge.net Aihe: Re: [Geoserver-users] Refresh a Geoserver PostGIS layer after adding a new column to the data source (postgis table)
Hi Jody,
Please let me know if you have any suggestions.
Regards
On Thu, Nov 2, 2023 at 10:14 PM Jody Garnett <jody.garnett@…84…> wrote:
The format may of changed a bit as the ability to add CQL expressions (and generate columns on the fly) was added in that time frame.
There is an options to refresh the column definition from the database table that may be more suitable than manually adding a column.
Jody Garnett
Thanks and Regards,
Sriharsha Yegireddi
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
