[Geoserver-users] reg: speed problem
Dear all!!!
I have 30000 shape file, thase i am publishing through geoserver 2.2 as WMS service…but when i am accessing those layer i am getting very slow performance…any suggestion???
Thanks and Regards
Nitin Mishra
Under what scenarios is your performance slow?
Usual performance tips:
  • slow when zoomed in? make sure a spatial index has been generated for the shapefile - it will generate one the first time you access.
  • slow when zoomed out? Optimise the style files for speed (using min scale denominator / max scale denominator rules) for example if the data has a scale hint you could use it to only draw some of the content. Make a second dataset of simplified geometry and swap between the two based on scale
There are more tips in the user guide and online:
Jody Garnett
On Sun, Jun 15, 2014 at 7:09 AM, Nitin Mishra <nitincse11@anonymised.com> wrote:
Dear all!!!
Thanks and Regards
Nitin Mishra
HPCC Systems Open Source Big Data Platform from LexisNexis Risk Solutions
Find What Matters Most in Your Big Data with HPCC Systems
Open Source. Fast. Scalable. Simple. Ideal for Dirty Data.
Leverages Graph Analysis for Fast Processing & Easy Data Exploration
http://p.sf.net/sfu/hpccsystems
Geoserver-users mailing list
