Hello everyone,
I am trying to use GeoServer 1.4 with PostGIS to store features that may have
a geometric value (optional!) and also relations to other features. I would
like to insert and query these features using WFS 1.0.0. Playing around a bit
I encountered several issues.
What is the best or standard way to realise (many-to-many) relations? First, I
created a simple feature table in Postgres/PostGIS with a foreign key to
itself:
CREATE TABLE some_places (
pid integer PRIMARY KEY,
place_name character varying(128) NOT NULL,
refers_to integer REFERENCES places
SELECT AddGeometryColumn (...,'place_geom',...);
Afterwards, I can easily define a new FeatureType within GeoServer. The
refers_to element is treated as a usual int attribute of the feature but
actually representing the id of the referenced feature. So I am able to follow
relations querying this feature id. However, I did not find a way to introduce
a many-to-many relationship because I need an additional table wich is not
referenced by the feature table directly.
I also found nice mechanisms in the GML simple profile spec where you can
define the feature type of the reference target. Is there a similar approach
in the WFS?
My second problem is that I cannot insert a place without a place_geom value
although the schema and the table definition allow this. As workaround I am
currently using a constant polygon with 0.0 values but I am not so happy about
it.
I would appreciate any hints and also references to docs that might help.
Thank you in advance!
Martin
This message has already been answered
http://www.nabble.com/Relations-between-features-with-WFS-and-PostGIS-tf2971393.html#a8316829
here .
Apologies for duplicate email! I had problems sending to a SourceForge
mailinglist with another email account.
martin
Martin Gruhn wrote:
Hello everyone,
have
would
bit
First, I
itself:
follow
introduce
approach
in the WFS?
value
am
about
it.
Martin
Join SourceForge.net's Techsay panel and you'll get the chance to share
your
opinions on IT & business topics through brief surveys - and earn cash
Geoserver-users mailing list
View this message in context: http://www.nabble.com/Relations-between-features-with-WFS-and-PostGIS-tf3015450.html#a8387567
