[Geoserver-users] Reload Catalog required to refresh ImageMosaic layer
I am dynamically updating a PostGIS indexed ImageMosaic store by copying files into place and updating the db table. However, newly loaded data does not automatically show up in WMS requests until I restart the server or do a catalog reload from the server status page.
According to my understanding of how ImageMosaic works, I don’t even understand how this is possible. Is the tile index being cached somewhere? And if so, why?
Jason Newmoyer
Newmoyer Geospatial Solutions
843.606.0424
jason@anonymised.com64…
Ciao Jason,
the only reason I can think of ( I'd need to check the code) is that
the new data falls outside the existing BBOX which might be cached in
GeoServer (not sure I'd need to check).
If that is the case you can recompute the bbox and do a put via rest
interface to update.
If that is not the case, can you clarify a bi tmore what you mean by
"does not automatically show up in WMS requests"?
Simone Giannecchini
Visit GeoSolutions Enterprise Support Services for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Mon, Apr 18, 2016 at 2:59 PM, Jason Newmoyer
According to my understanding of how ImageMosaic works, I don't even
And if so, why?
Jason Newmoyer
843.606.0424
Find and fix application performance issues faster with Applications Manager
Applications Manager provides deep performance insights into multiple tiers
of
your business applications. It resolves application problems quickly and
reduces your MTTR. Get your free trial!
IT infrastructure & Application Monitoring Tool - ManageEngine Applications Manager
Geoserver-users mailing list
Simone,
I found the edge of the data where the imagery data does not immediately show in the openlayers layer preview. It was right on the boundary of the layer bounds. So, I updated the bounds, widening it just a smidgen. I requested a new image and no change. I then went to Server Status and clicked the Clear Resources button this time. This time requesting a new image showed the new data.
The way I can tell where the new imagery data should be is I am overlaying a wireframe using the tile index as an actual layer.
So, it appears to me that the layer bounds is the cause, but that it is also being cached. And that cache may not be properly cleared when the layer definition is updated.
Jason
On Mon, Apr 18, 2016 at 1:23 PM, Simone Giannecchini <simone.giannecchini@anonymised.com> wrote:
Ciao Jason,
the only reason I can think of ( I’d need to check the code) is that
GeoServer (not sure I’d need to check).
“does not automatically show up in WMS requests”?
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
@simogeo
Founder/Director
D.Lgs. 196/2003.
privacy act (Legislative Decree June, 30 2003, no.196 - Italy’s New
And if so, why?
Jason Newmoyer
843.606.0424
of
https://ad.doubleclick.net/ddm/clk/302982198;130105516;z
Jason Newmoyer
843.606.0424
Hi Jason,
did you try using anything other than the openlayers preview?
As far as I know, the current preview just does not allow you to pan out
of the configured bounding box, so you might be seeing a limit in the WMS
service that’s actually baked in the preview itself.
Could you try with some other client?
On Mon, Apr 18, 2016 at 9:53 PM, Jason Newmoyer <jason@anonymised.com> wrote:
Simone,
Jason
Applications Manager provides deep performance insights into multiple tiers of
Jason Newmoyer
843.606.0424
On Mon, Apr 18, 2016 at 1:23 PM, Simone Giannecchini <simone.giannecchini@anonymised.com..1107…> wrote:
Ciao Jason,
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
And if so, why?
Jason Newmoyer
843.606.0424
of
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
Ciao Andrea,
the problem may also be with a client like QGIS that works by the
GetCapabilities where the cached BBOX is reported.
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
On Wed, Apr 20, 2016 at 9:31 AM, Andrea Aime
<andrea.aime@anonymised.com> wrote:
Hi Jason,
service that's actually baked in the preview itself.
Simone,
Jason
Jason Newmoyer
843.606.0424
Ciao Jason,
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
> copying
> does
> do a
> somewhere?
> And if so, why?
> Jason Newmoyer
> 843.606.0424
> Manager
> tiers
> of
> and
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
Manager
tiers of
Ing. Andrea Aime
@geowolf
Technical Lead
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
file/s allegato/i sono da considerarsi strettamente riservate. Il loro
utilizzo è consentito esclusivamente al destinatario del messaggio, per le
finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
via e-mail e di procedere alla distruzione del messaggio stesso,
cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
finalità diverse, costituisce comportamento contrario ai principi dettati
dal D.Lgs. 196/2003.
information in this message that has been received in error. The sender does
not give any warranty or accept liability as the content, accuracy or
On Wed, Apr 20, 2016 at 9:47 AM, Simone Giannecchini <
Ciao Andrea,
Indeed it can... but from memory, those clients normally ask whatever area
they are looking at, without
intersecting it with the bbox used in the caps, which is used instead for
"zoom to layer".
That said, it would indeed be nice to have the ability to mark a layer to
have a dynamic bbox, computed
on the fly each time... of course, that would also make caps generation
slower, but if one for any reason
cannot or does not want update the bbox using the rest api when data
changes, it's a way.
On the opposite end, it would be nice to be able to configure/cache time
and elevation instead, which are
always computed on the fly instead.
That is, allow the admin to choose between static and dynamic on a as
needed basis.
Both good subjects for sponsoring :-p
Ing. Andrea Aime
@geowolf
Technical Lead
I tried updating the bbox parameter in the URL of the OL preview, but it did not seem to restrict my ability to pan outside of that area. I will try in another client when I get back to that spot in my testing.
Thanks.
On Wed, Apr 20, 2016 at 3:31 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Jason,
Jason Newmoyer
843.606.0424
Simone,
Jason
Ing. Andrea Aime
@geowolf
Technical Lead
Jason Newmoyer
843.606.0424
jason@anonymised.com7364…
Ciao Jason,
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
And if so, why?
Jason Newmoyer
843.606.0424
of
Dynamic bbox might be a nice feature for data layers that update frequently.
In this case, I’m fine with making a REST call to expand the bbox. I’m just not sure if that actually clears the cached value properly. I will continue to test this.
On Wed, Apr 20, 2016 at 4:16 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Jason Newmoyer
843.606.0424
On Wed, Apr 20, 2016 at 9:47 AM, Simone Giannecchini <simone.giannecchini@anonymised.com> wrote:
Ciao Andrea,
Indeed it can… but from memory, those clients normally ask whatever area they are looking at, without
intersecting it with the bbox used in the caps, which is used instead for “zoom to layer”.
That said, it would indeed be nice to have the ability to mark a layer to have a dynamic bbox, computed
on the fly each time… of course, that would also make caps generation slower, but if one for any reason
cannot or does not want update the bbox using the rest api when data changes, it’s a way.
On the opposite end, it would be nice to be able to configure/cache time and elevation instead, which are
That is, allow the admin to choose between static and dynamic on a as needed basis.
Ing. Andrea Aime
@geowolf
Technical Lead
