On some layers, we have an error with the “Reloaded Feature Type” button when data structure has changed.
For some layers it works perfectly but it crashes on another. See the error below
Caused by: java.io.IOException: the SimpleFeatureType {layer_name} does not contains the configured attribute {attribute_name}. Check your schema configuration
We’ve discovered that this error occurs when the featuretype.xml contains tags.
Is somebody able to explain why some layer contains this xml attribute tags and others not, why those tags are sometimes written and sometimes not.
Best Regards
Sébastien DIAS
GROUPEMENT D’INTERET PUBLIC
AMENAGEMENT DU TERRITOIRE ET GESTION DES RISQUES
6, Parvis des Chartrons
33 075 BORDEAUX Cedex
Téléphone : 05 57 85 40 04
Email : sebastien.dias@anonymised.com
