[Geoserver-users] Requests with LANGUAGE Parameters
Dear Mailing-List,
currently we're facing a problem with this type of request to a wms service from GeoServer (2.22.0):
__WMS_URL__?LANGUAGE=ger&VERSION=1.3.0&SERVICE=WMS&REQUEST=GetCapabilities
Following error will be thrown:
javax.xml.transform.TransformerException: Translator error Translator error Content has been requested in one of the following languages: de. But there is no international content defined
Originally we havn't set a standard language and the INSPIRE ExtentedCapabilities are also disabled.
If we enable both - AND check the Checkbox i18n for the Title in the WMS Settings - AND enter the title for the language de, the problem will be solved.
But as a consequence the global contact information will be lost and we have to enable it for the workspace.
Is there any workaround, that GeoServer will use the standard values in the title, abstract, etc. fields without checking the i18n Checkboxes for those LANGUAGE-Requests?
Best regards,
Anna-Lena Hock
Dear Anna-Lena,
At the current state it seems that there is no workaround to avoid the issue you are facing without enabling the i18n support. Note however that you should be able to enable i18n for Contact information as well and add the de entries for the contact fields that you need. Mind that you will have to enable i18n as well for all the mandatory fields of service and layers (eg title) otherwise in the capabilities you will see an error message telling you that the entry doesn’t have i18n content.
Marco Volpini
Visit http://bit.ly/gs-services-us for more information.
Marco Volpini
Software Engineer
GeoSolutions Group
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
