Hi
In GeoServer 2.0.2 with user interface is possible to configure two layers with same name in different workspaces, but REST API methods to manage layers seem only using the layer name, no workspace information. So no possible to manage properly these layers with REST API.
This seem a bug or restriction in REST API. Any chance to be solve in 2.1?
Jose García
Hi Jose,
Yes, this is a known issue. The problem is that layers have no container. The idea is to add a container called a “map”, or i think we maybe changed the name to “context”. Anyways, it is a new configuration entity and would serve as the container for maps.
What you can do instead as a workaround is use a qualified layer name. For instance if you try to access a layer through the rest api that is prefixed by workspace name the api will recognize that. For instance:
GET /layers/topp:states.xml will respect the “topp:” prefix. Even though the official name of the layer is just states.
-Justin
On Tue, Jan 11, 2011 at 2:24 AM, jose garcia <josegar74@anonymised.com> wrote:
Hi
Jose García
Gaining the trust of online customers is vital for the success of any company
that requires sensitive data to be transmitted over the Web. Learn how to
best implement a security strategy that keeps consumers’ information secure
and instills the confidence they need to proceed with transactions.
http://p.sf.net/sfu/oracle-sfdevnl
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
