[Geoserver-users] REST Configuration API
Justin,
I reported the problem to JIRA.
Would it be possible for me to look at the source code and help debug
the problem?
Where can I find the source for the plugin?
-----Original Message-----
From: Justin Deoliveira [mailto:jdeolive@anonymised.com]
Sent: Tuesday, April 14, 2009 12:24 PM
To: Patel, Ronak Avinash (US SSA)
Cc: geoserver-users@lists.sourceforge.net; Froumis, James A (US SSA)
Subject: Re: [Geoserver-users] REST Configuration API
Ok, I was able to replicate the issue. Can you file a bug report in
jira?
Patel, Ronak Avinash (US SSA) wrote:
Justin,
It seemed that it created the image the first time, but when I tried
to
upload the same image again, it barfed.
6600 [main] INFO /geoserver - Initializing WebApplicationContext for
Struts ActionServlet 'action', module ''
6629 [main] INFO org.mortbay.log - Opened
/opt/geoserver-1.7.3/logs/2009_04_14.request.log
6640 [main] INFO org.mortbay.log - Started
SelectChannelConnector@anonymised.com:8080
14 Apr 11:36:27 DEBUG [geoserver.filters] - filtering
http://patel-dev.irad.net:8080/geoserver/rest/workspaces/leia11/coverage
stores/blah/file.geotiff
[security.RESTfulPathBasedFilterInvocationDefinitionMap] - Converted
URL
to lowercase, from:
'/rest/workspaces/leia11/coveragestores/blah/file.geotiff'; to:
'/rest/workspaces/leia11/coveragestores/blah/file.geotiff' and
httpMethod= PUT
[security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~
antPath= /** methodList= [Ljava.lang.String;@d0726d
[security.RESTfulPathBasedFilterInvocationDefinitionMap] - method[0]:
GET
[security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate
is:
'/rest/workspaces/leia11/coveragestores/blah/file.geotiff'; antPath is
/**; matchedPath=true; matchedMethods=false
antPath= /** methodList= [Ljava.lang.String;@1ccf342
POST
[security.RESTfulPathBasedFilterInvocationDefinitionMap] - method[1]:
DELETE
[security.RESTfulPathBasedFilterInvocationDefinitionMap] - method[2]:
PUT
is:
/**; matchedPath=true; matchedMethods=true
13637 [btpool0-8] INFO /geoserver - Initializing Spring
FrameworkServlet
'dispatcher'
14 Apr 11:36:27 DEBUG [gdal.erdasimg] - NITFFormatFactory is not
availaible.
14 Apr 11:36:27 DEBUG [gdal.jp2ecw] - JP2ECWFormatFactory is not
availaible.
14 Apr 11:36:27 DEBUG [gdal.ehdr] - EsriHdrFormatFactory is not
availaible.
14 Apr 11:36:27 DEBUG [gdal.jp2mrisd] - JP2MrSIDFormatFactory is not
availaible.
14 Apr 11:36:27 DEBUG [gdal.erdasimg] - ErdasImgFormatFactory is not
availaible.
14 Apr 11:36:27 DEBUG [gdal.dted] - DTEDFormatFactory is not
availaible.
14 Apr 11:36:27 DEBUG [gdal.mrsid] - MrSIDFormatFactory is not
availaible.
14 Apr 11:36:27 DEBUG [gce.arcgrid] - ArcGridFormatFactory is
availaible.
14 Apr 11:36:27 DEBUG [gdal.jp2k] - JP2KFormatFactory is not
availaible.
14 Apr 11:36:27 DEBUG [gdal.ecw] - ECWFormatFactory is not availaible.
14 Apr 11:36:27 DEBUG [gce.arcgrid] - Creating a new ArcGriFormat.
14 Apr 11:36:27 INFO [catalog.rest] - PUT file, mimetype:
image/geotiff
14 Apr 11:36:27 INFO [catalog.rest] - Auto-configuring coverage store:
blah
14 Apr 11:36:27 INFO [geotools.factory] - Factory implementations for
category GridCoverageFactory:
  org.geotools.coverage.grid.GridCoverageFactory
availaible.
availaible.
availaible.
availaible.
availaible.
availaible.
availaible.
availaible.
availaible.
14 Apr 11:36:27 DEBUG [geoserver.global] - In method store DataDTO
14 Apr 11:36:27 DEBUG [geoserver.global] - In method storeFormat
14 Apr 11:36:27 DEBUG [geoserver.global] - In method storeCoverages
14 Apr 11:36:28 DEBUG [geoserver.global] - In method storeCoverage
ERROR HERE
14 Apr 11:36:46 DEBUG [geoserver.filters] - filtering
URL
to lowercase, from:
httpMethod= PUT
GET
is:
POST
DELETE
PUT
is:
14 Apr 11:36:46 DEBUG [gdal.erdasimg] - NITFFormatFactory is not
availaible.
14 Apr 11:36:46 DEBUG [gdal.jp2ecw] - JP2ECWFormatFactory is not
availaible.
14 Apr 11:36:46 DEBUG [gdal.ehdr] - EsriHdrFormatFactory is not
availaible.
14 Apr 11:36:46 DEBUG [gdal.jp2mrisd] - JP2MrSIDFormatFactory is not
availaible.
14 Apr 11:36:46 DEBUG [gdal.erdasimg] - ErdasImgFormatFactory is not
availaible.
14 Apr 11:36:46 DEBUG [gdal.dted] - DTEDFormatFactory is not
availaible.
14 Apr 11:36:46 DEBUG [gdal.mrsid] - MrSIDFormatFactory is not
availaible.
14 Apr 11:36:46 DEBUG [gce.arcgrid] - ArcGridFormatFactory is
availaible.
14 Apr 11:36:46 DEBUG [gdal.jp2k] - JP2KFormatFactory is not
availaible.
14 Apr 11:36:46 DEBUG [gdal.ecw] - ECWFormatFactory is not availaible.
14 Apr 11:36:46 DEBUG [gce.arcgrid] - Creating a new ArcGriFormat.
14 Apr 11:36:46 INFO [catalog.rest] - PUT file, mimetype:
image/geotiff
14 Apr 11:36:46 INFO [catalog.rest] - Using existing coverage store:
blah
availaible.
availaible.
availaible.
availaible.
availaible.
availaible.
availaible.
availaible.
availaible.
14 Apr 11:36:46 ERROR [geoserver.rest] - Error auto-configuring
coverage:java.lang.NullPointerException
14 Apr 11:36:46 DEBUG [geoserver.rest] -
org.geoserver.rest.RestletException: java.lang.RuntimeException:
        at
org.geoserver.catalog.rest.CoverageStoreFileResource.handlePut(CoverageS
toreFileResource.java:165)
        at org.restlet.Finder.handle(Finder.java:298)
        at
org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.ja
va:38)
        at org.restlet.Filter.doHandle(Filter.java:105)
        at org.restlet.Filter.handle(Filter.java:134)
        at org.restlet.Router.handle(Router.java:444)
        at
com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverte
r.java:129)
        at
org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.j
ava:79)
        at
org.springframework.web.servlet.mvc.AbstractController.handleRequest(Abs
tractController.java:153)
        at
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handl
e(SimpleControllerHandlerAdapter.java:48)
        at
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherS
ervlet.java:875)
        at
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherSe
rvlet.java:809)
        at
org.springframework.web.servlet.FrameworkServlet.processRequest(Framewor
kServlet.java:571)
        at
org.springframework.web.servlet.FrameworkServlet.doPut(FrameworkServlet.
java:521)
        at
javax.servlet.http.HttpServlet.service(HttpServlet.java:730)
        at
javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
        at
org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
        at
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHan
dler.java:1093)
        at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharac
terEncodingFilter.java:108)
        at
dler.java:1084)
        at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(Filt
erChainProxy.java:264)
        at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterS
ecurityInterceptor.java:107)
        at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(Filte
rSecurityInterceptor.java:72)
        at
erChainProxy.java:274)
        at
org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTransl
ationFilter.java:110)
        at
        at
org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter
(AnonymousProcessingFilter.java:125)
        at
        at
org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProce
ssingFilter.java:178)
        at
        at
org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(H
ttpSessionContextIntegrationFilter.java:229)
        at
        at
org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:1
48)
        at
org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java
:98)
        at
dler.java:1084)
        at
org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
        at
dler.java:1084)
        at
org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.jav
a:163)
        at
dler.java:1084)
        at
org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:47)
        at
dler.java:1084)
        at
org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
        at
org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:2
16)
        at
org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
        at
org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
        at
org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
        at
org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandler
Collection.java:206)
        at
org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.jav
a:114)
        at
org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
        at org.mortbay.jetty.Server.handle(Server.java:324)
        at
org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
        at
org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.j
ava:842)
        at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:648)
        at
org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:205)
        at
org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
        at
org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:
395)
        at
org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.ja
va:450)
Caused by: java.lang.RuntimeException: java.lang.NullPointerException
        at
org.geoserver.catalog.CatalogBuilder.update(CatalogBuilder.java:232)
        at
org.geoserver.catalog.CatalogBuilder.updateCoverage(CatalogBuilder.java:
155)
        at
toreFileResource.java:132)
        ... 56 more
Caused by: java.lang.NullPointerException
        at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.jav
a:39)
        at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessor
Impl.java:25)
        at
org.geoserver.catalog.CatalogBuilder.updateMapProperty(CatalogBuilder.ja
va:251)
        at
org.geoserver.catalog.CatalogBuilder.update(CatalogBuilder.java:224)
        ... 58 more
Sent: Tuesday, April 14, 2009 11:29 AM
Both, they both contain a few related bug fixes not in the 1.7.3
release.
The nightly build of geoserver? Or the plugin?
Sent: Tuesday, April 14, 2009 11:26 AM
Ok, this fix went in after 1.7.3. Is there any chance you could try
it
out with the latest nightly build? That will at least give us the
exception that is occurring. Sorry for the inconvenience.
-Justin
I downloaded the latest stable build 1.7.3a. I just downloaded that
and
the REST plugin from geoserver.org today.
Sent: Tuesday, April 14, 2009 11:24 AM
Hmmm... I am still not seeing the exception in the logs. Come to
think
of it I think i added the logging statement in my latest patch to
fix
the related issue. What build are you running?
Hi Justin,
I set the logs to verbose like you said and I get the following
error:
14 Apr 11:13:33 DEBUG [geoserver.filters] - filtering
Converted
URL
to lowercase, from:
httpMethod= PUT
antPath= /** methodList= [Ljava.lang.String;@893918
method[0]:
GET
Candidate
is:
is
antPath= /** methodList= [Ljava.lang.String;@327236
method[0]:
POST
method[1]:
DELETE
method[2]:
PUT
Candidate
is:
is
14 Apr 11:13:33 DEBUG [gce.arcgrid] - ArcGridFormatFactory is
availaible.
14 Apr 11:13:33 DEBUG [gce.arcgrid] - Creating a new ArcGriFormat.
14 Apr 11:13:33 INFO [catalog.rest] - PUT file, mimetype:
image/geotiff
14 Apr 11:13:33 INFO [catalog.rest] - Using existing coverage
store:
blah
availaible.
14 Apr 11:13:33 ERROR [geoserver.rest] - Error auto-configuring
Like you said, I blow away the contents of the
/opt/geoserver-1.7.3/data_dir/data/coveragestorename to get rid of
my
geotiff file.
I see that the HTTP PUT does indeed upload my file to geoserver
fine.
The problem seems to be with processing the geotiff file after a
successfull upload.
Hopefully this is helpful.
Ronak Patel
Sent: Tuesday, April 14, 2009 10:43 AM
SSA)
Hi Patel,
Can you log into the admin console and turn on verbose logging.
Config -> Server and change logging to GEOSERVER_DEVELOPER. And
then
try
again including the stack trace from the error log.
Also, when files are uploaded they get put into the "data"
directory
under neath GEOSERVER_DATA_DIR, you may want to try clearing out
the
appropriate sub directories to ensure a "fresh" start. Which
reminds
me
I fixed an issue recently with files not being able to overwrite
existing files, that might be coming into play here.
-Justin
Justin,
By the way, I am actually PUTing the image to the server and NOT
POSTing.
I keep getting this error when I try to upload a png or jpg:
14 Apr 10:00:08 INFO [catalog.rest] - PUT file, mimetype:
image/jpeg
14 Apr 10:00:08 INFO [catalog.rest] - Using existing coverage
store:
blah
14 Apr 10:00:08 ERROR [geoserver.rest] - Error auto-configuring
coverage:Unsupported file format
14 Apr 10:00:22 INFO [catalog.rest] - PUT file, mimetype:
image/png
14 Apr 10:00:22 INFO [catalog.rest] - Using existing coverage
store:
blah
14 Apr 10:00:22 ERROR [geoserver.rest] - Error auto-configuring
When I try to upload a GeoTiff, I always get the following error:
14 Apr 10:03:49 INFO [catalog.rest] - PUT file, mimetype:
image/tif
14 Apr 10:03:49 INFO [catalog.rest] - Using existing coverage
store:
blah
14 Apr 10:03:49 ERROR [geoserver.rest] - Error auto-configuring
I hope that helps in debugging the situation.
Thanks a million!!
Ronak Patel
Sent: Tuesday, April 14, 2009 9:50 AM
To: 'Justin Deoliveira'
SSA)
Subject: RE: [Geoserver-users] REST Configuration API
Justin,
I desperately tried all day yesterday to try to POST a coverage
and
get
Geoserver to accept my image (a GeoTiff).
I am POSTing to a CoverageStore and Workspace that I create using
the
REST API.
I am POSTing the following:
URL:
/geoserver/rest/workspaces/testWorkspace/coveragestores/testStore/file.g
eotiff
POST ContentType image/tif and the POST content is the file.
I noticed that if I set the configure=none&coverageName=test flags
in
the URL, then the file is ingested by Geoserver without
complaining.
When I don't set these cgi parameters, things fail and complain.
Why does this happen?
Also, do I have to create a layer to host the image in the WMS? Or
is
this done automatically?
Thanks a million!!
Ronak Patel
Justin Deoliveira
OpenGeo - http://opengeo.org
