Yeah... that json looks a bit wierd.
"featureTypes": "shp"
Not sure what you mean there.
And for the workspace, i would avoid the nulls and just reference by name. Actually you don't really need to specify it since it is inferred from the URL you are POSTing or PUTing to.
Or just include it by name:
"workspace":{"name":"hello"}
or even just:
"workspace": "hello"
should work.
-Justin
Patel, Ronak Avinash (US SSA) wrote:
Justin,
I am putting the following JSON:
POST /geoserver/rest/workspaces/hello/datastores HTTP/1.1
Authorization: Basic YWRtaW46Z2Vvc2VydmVy
Content-Type: application/json
User-Agent: Java/1.6.0_13
Host: patel-xp.irad.net:9090
Accept: text/html, image/gif, image/jpeg, *; q=.2, */*; q=.2
Connection: keep-alive
Content-Length: 139{"dataStore":{"enabled":"true","featureTypes":"shp","name":"testzip","wo
rkspace":{"coverageStores":null,"dataStores":null,"name":"hello"}}}Are those nulls the problem?? Or the featureTypes parameter?
Ronak Patel
-----Original Message-----
From: Justin Deoliveira [mailto:jdeolive@anonymised.com] Sent: Wednesday, August 05, 2009 4:53 PM
To: Patel, Ronak Avinash (US SSA)
Subject: Re: [Geoserver-users] REST NPE while uploading features to
GeoserverHi Ronak,
The error means that there is a problem with the xml you are uploading. Can you include the request and the xml you are trying to upload.
As for the zip file, it is the "regular" zip format (pkzip or whichever)
, not gzip. The zip file you sent never got through to me. Is there anyway you can post it? Or just send it to me direcetly, not cc'ing the public list.
-Justin
Justin,
I tried setting the logging to GEOSERVER_DEVELOPER and it spit out
this
output to me:
05 Aug 13:37:33 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDe
finitionMap] - Candidate is: '/rest/workspaces/hello/datastores'; antPath is /**
; matchedPath=true; matchedMethods=true
05 Aug 13:37:33 ERROR [org.geoserver.rest] -
com.thoughtworks.xstream.converters.ConversionException: featureTypes
featureT
ypes : featureTypes : featureTypes
*---- Debugging information ----*
*message : featureTypes : featureTypes*
*cause-exception : com.thoughtworks.xstream.mapper.CannotResolveClassExceptio*
*n*
*cause-message : featureTypes : featureTypes*
*class : org.geoserver.catalog.impl.DataStoreInfoImpl*
*required-type : org.geoserver.catalog.impl.DataStoreInfoImpl*
*line number : -1*
at com.thoughtworks.xstream.core.TreeUnmarshaller.convert(TreeUnmarshall
er.java:89)
at com.thoughtworks.xstream.core.TreeUnmarshaller.convertAnother(TreeUnm
arshaller.java:76)
arshaller.java:60)
at com.thoughtworks.xstream.core.TreeUnmarshaller.start(TreeUnmarshaller
.java:137)
at com.thoughtworks.xstream.core.AbstractTreeMarshallingStrategy.unmarsh
al(AbstractTreeMarshallingStrategy.java:33)
at
com.thoughtworks.xstream.XStream.unmarshal(XStream.java:923)
at
com.thoughtworks.xstream.XStream.unmarshal(XStream.java:909)
at com.thoughtworks.xstream.XStream.fromXML(XStream.java:861)
at org.geoserver.config.util.XStreamPersister.load(XStreamPersister.java
:380)
at org.geoserver.catalog.rest.AbstractCatalogResource$2.read(AbstractCat
alogResource.java:72)
at org.geoserver.rest.format.StreamDataFormat.toObject(StreamDataFormat.
java:33)
at org.geoserver.rest.ReflectiveResource.handlePost(ReflectiveResource.j
ava:112)
at org.restlet.Finder.handle(Finder.java:296)
at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet
.java:38)
at org.restlet.Filter.doHandle(Filter.java:105)
at org.restlet.Filter.handle(Filter.java:134)
at org.restlet.Router.handle(Router.java:444)
at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConve
rter.java:129)
at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatche
r.java:79)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(
AbstractController.java:153)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.ha
ndle(SimpleControllerHandlerAdapter.java:48)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(Dispatch
erServlet.java:875)
at org.springframework.web.servlet.DispatcherServlet.doService(Dispatche
rServlet.java:809)
at org.springframework.web.servlet.FrameworkServlet.processRequest(Frame
workServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServ
Which class cannot be loaded???
Ronak
*Sent:* Wednesday, August 05, 2009 12:42 PM
*To:* Justin Deoliveira
*Cc:* geoserver-users@lists.sourceforge.net
*Subject:* Re: [Geoserver-users] REST NPE while uploading features to GeoserverJustin,
Out of curiosity, does the ZIP file have to be a GZIP file? Or a
regular
zip file is good as well?
I can write out either using Java.
Please let me know what format I need....
Ronak
*Sent:* Tuesday, August 04, 2009 6:32 PM
*Subject:* REST NPE while uploading features to GeoserverHey Justin,
Thanks for the loads of help you've provided.
I had another question:
I'm trying to upload a shapefile (and its associated .shx and .dbf) files as a zip file to geoserver using the REST configuration but I
seem
to get a NullPointerException back:
PUT
/geoserver/rest/workspaces/hello/datastores/testzip/file.shp?coverageNam
e=testHTTP/1.1
Content-Type: application/zip
Content-Length: 495
[The zip file containing the zip file]
The zip file I am sending is created by 7zip.
I get this error inside Geoserver:
04 Aug 18:29:56 ERROR [geoserver.rest] - Error occured unzipping file:error in o
pening zip file
Ronak Patel
Senior Software Engineer
BAE Systems NS
San Diego, CA
Justin Deoliveira
OpenGeo - http://opengeo.org
