Justin,
Even with leaving this off I get a NullPointerException on upload.
Is the problem the fact that I don't have a .prj file?
Would that solve the NullPointerException?
Nothing else looks obvious...
Btw, does Geoserver version 1.7.6 contain any fixes for this?
Ronak Patel
-----Original Message-----
From: Justin Deoliveira [mailto:jdeolive@anonymised.com]
Sent: Wednesday, August 12, 2009 1:13 PM
To: Patel, Ronak Avinash (US SSA)
Subject: Re: [Geoserver-users] REST NPE while uploading features to
Geoserver
Just leave it off. It is really on used to provide clients with a link
to any feature tyeps contained by the datastore. It really only makes
sense when doing a GET, so the client can traverse the links to the
contained feature types.
Patel, Ronak Avinash (US SSA) wrote:
Justin,
What should I be entering in the featureTypes element? Should I be
entering anything?? What does the featureTypes element used for? What
"type" is it?Ronak Patel
Sent: Wednesday, August 12, 2009 7:46 AM
GeoserverYeah... that json looks a bit wierd.
"featureTypes": "shp"
Not sure what you mean there.
And for the workspace, i would avoid the nulls and just reference by
name. Actually you don't really need to specify it since it is
inferred
from the URL you are POSTing or PUTing to.
Or just include it by name:
"workspace":{"name":"hello"}
or even just:
"workspace": "hello"
should work.
-Justin
Justin,
I am putting the following JSON:
POST /geoserver/rest/workspaces/hello/datastores HTTP/1.1
Authorization: Basic YWRtaW46Z2Vvc2VydmVy
Content-Type: application/json
User-Agent: Java/1.6.0_13
Host: patel-xp.irad.net:9090
Accept: text/html, image/gif, image/jpeg, *; q=.2, */*; q=.2
Connection: keep-alive
Content-Length: 139
{"dataStore":{"enabled":"true","featureTypes":"shp","name":"testzip","wo
rkspace":{"coverageStores":null,"dataStores":null,"name":"hello"}}}
Are those nulls the problem?? Or the featureTypes parameter?
Ronak Patel
Sent: Wednesday, August 05, 2009 4:53 PM
GeoserverHi Ronak,
The error means that there is a problem with the xml you are
uploading.
Can you include the request and the xml you are trying to upload.
As for the zip file, it is the "regular" zip format (pkzip or
whichever)
, not gzip. The zip file you sent never got through to me. Is there
anyway you can post it? Or just send it to me direcetly, not cc'ingthe
public list.
-Justin
Justin,
I tried setting the logging to GEOSERVER_DEVELOPER and it spit out
this
output to me:
05 Aug 13:37:33 DEBUG
[org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/workspaces/hello/datastores';
antPath is /**; matchedPath=true; matchedMethods=true
05 Aug 13:37:33 ERROR [org.geoserver.rest] -
com.thoughtworks.xstream.converters.ConversionException:
featureTypes
featureT
ypes : featureTypes : featureTypes
*---- Debugging information ----*
*message : featureTypes : featureTypes*
*cause-exception :
com.thoughtworks.xstream.mapper.CannotResolveClassExceptio**n*
*cause-message : featureTypes : featureTypes*
*class : org.geoserver.catalog.impl.DataStoreInfoImpl*
*required-type : org.geoserver.catalog.impl.DataStoreInfoImpl*
*line number : -1*
at
com.thoughtworks.xstream.core.TreeUnmarshaller.convert(TreeUnmarshall
er.java:89)
at
com.thoughtworks.xstream.core.TreeUnmarshaller.convertAnother(TreeUnm
arshaller.java:76)
at
arshaller.java:60)
at
com.thoughtworks.xstream.core.TreeUnmarshaller.start(TreeUnmarshaller
.java:137)
at
com.thoughtworks.xstream.core.AbstractTreeMarshallingStrategy.unmarsh
al(AbstractTreeMarshallingStrategy.java:33)
at
com.thoughtworks.xstream.XStream.unmarshal(XStream.java:923)
at
com.thoughtworks.xstream.XStream.unmarshal(XStream.java:909)
at
com.thoughtworks.xstream.XStream.fromXML(XStream.java:861)
at
org.geoserver.config.util.XStreamPersister.load(XStreamPersister.java
:380)
at
org.geoserver.catalog.rest.AbstractCatalogResource$2.read(AbstractCat
alogResource.java:72)
at
org.geoserver.rest.format.StreamDataFormat.toObject(StreamDataFormat.
java:33)
at
org.geoserver.rest.ReflectiveResource.handlePost(ReflectiveResource.j
ava:112)
at org.restlet.Finder.handle(Finder.java:296)
at
org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet
.java:38)
at org.restlet.Filter.doHandle(Filter.java:105)
at org.restlet.Filter.handle(Filter.java:134)
at org.restlet.Router.handle(Router.java:444)
at
com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConve
rter.java:129)
at
org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatche
r.java:79)
at
org.springframework.web.servlet.mvc.AbstractController.handleRequest(
AbstractController.java:153)
at
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.ha
ndle(SimpleControllerHandlerAdapter.java:48)
at
org.springframework.web.servlet.DispatcherServlet.doDispatch(Dispatch
erServlet.java:875)
at
org.springframework.web.servlet.DispatcherServlet.doService(Dispatche
rServlet.java:809)
at
org.springframework.web.servlet.FrameworkServlet.processRequest(Frame
workServlet.java:571)
at
org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServ
Which class cannot be loaded???
Ronak
*Sent:* Wednesday, August 05, 2009 12:42 PM
*To:* Justin Deoliveira
*Cc:* geoserver-users@lists.sourceforge.net
*Subject:* Re: [Geoserver-users] REST NPE while uploading features
to
Geoserver
Justin,
Out of curiosity, does the ZIP file have to be a GZIP file? Or a
regular
zip file is good as well?
I can write out either using Java.
Please let me know what format I need....
Ronak
*Sent:* Tuesday, August 04, 2009 6:32 PM
*Subject:* REST NPE while uploading features to GeoserverHey Justin,
Thanks for the loads of help you've provided.
I had another question:
I'm trying to upload a shapefile (and its associated .shx and .dbf)
files as a zip file to geoserver using the REST configuration but Iseem
to get a NullPointerException back:
PUT
/geoserver/rest/workspaces/hello/datastores/testzip/file.shp?coverageNam
e=test
HTTP/1.1
Content-Type: application/zip
Content-Length: 495
[The zip file containing the zip file]
The zip file I am sending is created by 7zip.
I get this error inside Geoserver:
04 Aug 18:29:56 ERROR [geoserver.rest] - Error occured unzipping
file:error in opening zip file
Ronak Patel
Senior Software Engineer
BAE Systems NS
San Diego, CA
Justin Deoliveira
OpenGeo - http://opengeo.org
Let Crystal Reports handle the reporting - Free Crystal Reports 2008
30-Day
trial. Simplify your report design, integration and deployment - and
focus on
what you do best, core application coding. Discover what's new with
Crystal Reports now. http://p.sf.net/sfu/bobj-july
Geoserver-users mailing list
