Thomas, Justin
I developed some changes to an older version of GeoServer/GeoTools (2.2 / 8) in order to enable base64 complex objects management at the WPS level.
I never found enough time to send a patch as required by current policies, but if you drop me a line I will share them with you and maybe that could be useful
Fabrizio
=======From: Justin Deoliveira <jdeolive@anonymised.com>=====
Hey Thomas,
On Fri, Jul 5, 2013 at 12:25 PM, <Thomas.Wanderer@anonymised.com> wrote:
We?re planning to return a zip-file. We were hoping that it?s possible
to return a file via the scripting plugin, but of course this cannot be
simply the path as string, so we were thinking it might be possible by
providing a file object.
Right, i got that from the first post but what does the zip file contain is
my questions. Regardless i am thinking your use case is probably not
supported via a wps plugin. You could however use an “app” hook which
basically gives you an http invokable endpoint where you are free to return
any sort of content you choose.
We really hope this is somehow possible but do not know in which way we?d
have to provide results to make Geoserver (WPS) return a RawOutput instead
of a ResultDocument and how to specify a Content-Type or Mime-Type.******
Can you open a jira issue for this. Thanks.
Thanks,****
Thomas****
Von: Justin Deoliveira [mailto:jdeolive@anonymised.com]
Gesendet: Freitag, 5. Juli 2013 17:07
An: Herle, Stefan
Betreff: Re: [Geoserver-users] Returning any kind of file with WPS
python script****
Hey Stefan,****
What sort of data are you returning from the process? If you can provide a
bit more info that would be great.****
-Justin****
On Fri, Jul 5, 2013 at 6:38 AM, <Stefan.Herle@anonymised.com> wrote:****
Hey,****
I am trying to return a file (.zip) in a WPS python script but I have no
clue which type to choose for the output in the python decorator. ****I know that it is possible to define a raw data output in general but
what are the specific type mappings used in the WPS python script.****
Thanks!****
