On 11/11/16 21:43, Andrea Aime wrote:
On Thu, Nov 10, 2016 at 9:41 PM, Ben Caradoc-Davies <ben@anonymised.com>
wrote:Are there use-cases in which it is desirable to leave the file.encoding
property unset? Setting this as the default behaviour would likely improve
the experience of users with a non-UTF8 default encoding.Eh, I'm not sure.
In particular, what happens if -Dfile.encoding=UTF8 is set on platform with a non-US-ASCII Windows code page, and the SLD editor is used to edit an SLD that uses this code page (not UTF-8)?
Setting -Dfile.encoding=UTF8 in the Windows startup scripts might break things for some users.
A better solution might be for the encoding to be detected from the SLD when it is written. I am not volunteering.
I support all encodings ... as long as they are UTF-8:
http://utf8everywhere.org/
Kind regards,
Director
Transient Software Limited <http://transient.nz/>
New Zealand
