Hello list,
I’ve been trying to get GeoServer to run in Azure, by simply downloading the WAR file (https://docs.geoserver.org/stable/en/user/installation/war.html), creating a new Azure Web App instance (Linux / Tomcat 8.5 or 9), uploading the WAR file and accessing /geoserver, but I have not been successful. Both https://geoserver.geo-solutions.it/educational/en/install_run/gs_install.html and https://kvaes.wordpress.com/2017/10/06/azure-app-service-deploying-a-java-webapp-geoserver-to-azure/ seem to indicate the file should be extracted and it “simply works”…
As a beginner in both GeoServer and Azure, I’m stumped, and hope someone can help getting a step further. Log is as follows:
2021-02-15T09:22:19.384336915Z _____
2021-02-15T09:22:19.384386017Z / _ \ __________ _________ ____
2021-02-15T09:22:19.384391917Z / /_\ ___ / | _ __ _/ __ \
2021-02-15T09:22:19.384397317Z / | / /| | /| | /\ ___/
2021-02-15T09:22:19.384400817Z _| /____ _/ || __ >
2021-02-15T09:22:19.384404417Z / / /
2021-02-15T09:22:19.384407918Z A P P S E R V I C E O N L I N U X
2021-02-15T09:22:19.384411118Z
2021-02-15T09:22:19.384414218Z Documentation: http://aka.ms/webapp-linux
2021-02-15T09:22:19.384417418Z
2021-02-15T09:22:19.384420718Z NOTE: No files or system changes outside of /home will persist beyond your application’s current session. /home is your application’s persistent storage and is shared across all the server instances.
2021-02-15T09:22:19.384425618Z
2021-02-15T09:22:19.384428618Z
2021-02-15T09:22:19.401821653Z Setup openrc …
2021-02-15T09:22:20.129881919Z * Caching service dependencies … [ ok ]
2021-02-15T09:22:20.180482365Z Updating /etc/ssh/sshd_config to use PORT 2222
2021-02-15T09:22:20.188248948Z Starting ssh service…
2021-02-15T09:22:22.371577911Z ssh-keygen: generating new host keys: RSA DSA ECDSA ED25519
2021-02-15T09:22:25.494425352Z * Starting sshd … [ ok ]
2021-02-15T09:22:25.514991303Z ## Printing build info…
2021-02-15T09:22:25.528404592Z PACKAGE | VERSION | COMMIT
2021-02-15T09:22:25.528457994Z Microsoft.AppService.EasyAuthExtensionsJava | 1.0.011720002-alpha-793ad718 | 793ad718
2021-02-15T09:22:25.528464294Z Microsoft.AppService.WebsitesExtensionsJava | 1.0.011730003-alpha-53ae38d3 | 53ae38d3
2021-02-15T09:22:25.528468194Z self | 1.0.011730002-alpha-c6f00046 | c6f00046
2021-02-15T09:22:25.530133655Z ## Done printing build info.
2021-02-15T09:22:26.645180139Z Made a local copy of the app and using SITEROOT=/usr/local/tomcat/webapps
2021-02-15T09:22:26.646215277Z Add public certificates to keystore if exists…
2021-02-15T09:22:26.647083709Z Add private certificates to keystore if exists…
2021-02-15T09:22:26.691649735Z STARTUP_FILE=
2021-02-15T09:22:26.696569414Z STARTUP_COMMAND=
2021-02-15T09:22:26.696934228Z No STARTUP_FILE available.
2021-02-15T09:22:26.697273640Z No STARTUP_COMMAND defined.
2021-02-15T09:22:26.697285740Z Starting Tomcat with CATALINA_BASE set to “”
2021-02-15T09:22:26.698024867Z Launched child process with pid: 121
2021-02-15T09:22:26.698863298Z Waiting for main process to exit. global_pid_main=121
2021-02-15T09:22:26.704511204Z Waiting for global_pid_main == 121
2021-02-15T09:22:26.808718606Z Picked up JAVA_TOOL_OPTIONS: -Djava.net.preferIPv4Stack=true
2021-02-15T09:22:27.703747663Z 15-Feb-2021 09:22:27.689 WARNING [main] org.apache.catalina.startup.ClassLoaderFactory.validateFile Problem with directory [/home/tomcat/lib], exists: [false], isDirectory: [false], canRead: [false]
2021-02-15T09:22:27.707909114Z 15-Feb-2021 09:22:27.704 WARNING [main] org.apache.catalina.startup.ClassLoaderFactory.validateFile Problem with directory [/home/tomcat/lib], exists: [false], isDirectory: [false], canRead: [false]
2021-02-15T09:22:30.841323838Z 15-Feb-2021 09:22:30.839 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version name: Apache Tomcat/8.5.53
2021-02-15T09:22:30.848082984Z 15-Feb-2021 09:22:30.847 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server built: Mar 11 2020 10:01:39 UTC
2021-02-15T09:22:30.848688206Z 15-Feb-2021 09:22:30.848 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version number: 8.5.53.0
2021-02-15T09:22:30.850378468Z 15-Feb-2021 09:22:30.850 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name: Linux
2021-02-15T09:22:30.850984890Z 15-Feb-2021 09:22:30.850 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version: 5.4.0-1031-azure
2021-02-15T09:22:30.910040545Z 15-Feb-2021 09:22:30.851 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture: amd64
2021-02-15T09:22:30.910094847Z 15-Feb-2021 09:22:30.857 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Java Home: /usr/lib/jvm/zulu-8-azure-jre-headless-tools_8.44.0.11-8.0.242-linux_musl_x64
2021-02-15T09:22:30.910112147Z 15-Feb-2021 09:22:30.857 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version: 1.8.0_242-b20
2021-02-15T09:22:30.910116148Z 15-Feb-2021 09:22:30.857 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor: Azul Systems, Inc.
2021-02-15T09:22:30.910119948Z 15-Feb-2021 09:22:30.867 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE: /usr/local/tomcat
2021-02-15T09:22:30.910123848Z 15-Feb-2021 09:22:30.870 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME: /usr/local/tomcat
2021-02-15T09:22:30.910127648Z 15-Feb-2021 09:22:30.870 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.net.preferIPv4Stack=true
2021-02-15T09:22:30.910131448Z 15-Feb-2021 09:22:30.870 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=/usr/local/tomcat/conf/logging.properties
2021-02-15T09:22:30.910135148Z 15-Feb-2021 09:22:30.871 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
2021-02-15T09:22:31.028461965Z 15-Feb-2021 09:22:30.871 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xverify:none
2021-02-15T09:22:31.028476166Z 15-Feb-2021 09:22:30.871 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dsite.logdir=/home/LogFiles
2021-02-15T09:22:31.028497567Z 15-Feb-2021 09:22:30.871 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=/usr/local/tomcat/conf/logging.properties
2021-02-15T09:22:31.028501567Z 15-Feb-2021 09:22:30.888 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djdk.tls.ephemeralDHKeySize=2048
2021-02-15T09:22:31.028507467Z 15-Feb-2021 09:22:30.888 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.protocol.handler.pkgs=org.apache.catalina.webresources
2021-02-15T09:22:31.028510967Z 15-Feb-2021 09:22:30.889 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
2021-02-15T09:22:31.028514267Z 15-Feb-2021 09:22:30.889 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dsite.azMonlogdir=/var/log/diagnosticLogs
2021-02-15T09:22:31.028517567Z 15-Feb-2021 09:22:30.889 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dsite.root=/usr/local/tomcat/webapps
2021-02-15T09:22:31.028520668Z 15-Feb-2021 09:22:30.890 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dsite.unpackWARs=false
2021-02-15T09:22:31.028523968Z 15-Feb-2021 09:22:30.890 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dsite.tempdir=/tmp
2021-02-15T09:22:31.028527068Z 15-Feb-2021 09:22:30.955 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dport.http=80
2021-02-15T09:22:31.028530368Z 15-Feb-2021 09:22:31.011 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.instance.name=lw0sdlwk000014
2021-02-15T09:22:31.028533568Z 15-Feb-2021 09:22:31.011 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djdk.tls.ephemeralDHKeySize=2048
2021-02-15T09:22:31.028536868Z 15-Feb-2021 09:22:31.012 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.protocol.handler.pkgs=org.apache.catalina.webresources
2021-02-15T09:22:31.028540168Z 15-Feb-2021 09:22:31.012 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dorg.apache.catalina.security.SecurityListener.UMASK=0022
2021-02-15T09:22:31.028543468Z 15-Feb-2021 09:22:31.012 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dignore.endorsed.dirs=
2021-02-15T09:22:31.028546668Z 15-Feb-2021 09:22:31.018 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=/usr/local/tomcat
2021-02-15T09:22:31.028550369Z 15-Feb-2021 09:22:31.018 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=/usr/local/tomcat
2021-02-15T09:22:31.028554169Z 15-Feb-2021 09:22:31.018 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=/usr/local/tomcat/temp
2021-02-15T09:22:31.028558269Z 15-Feb-2021 09:22:31.020 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: [/usr/lib/jvm/zulu-8-azure-jre-headless-tools_8.44.0.11-8.0.242-linux_musl_x64/lib/amd64/server:/usr/lib/jvm/zulu-8-azure-jre-headless-tools_8.44.0.11-8.0.242-linux_musl_x64/lib/amd64:/usr/lib/jvm/zulu-8-azure-jre-headless-tools_8.44.0.11-8.0.242-linux_musl_x64/…/lib/amd64:/usr/java/packages/lib/amd64:/usr/lib64:/lib64:/lib:/usr/lib]
2021-02-15T09:22:31.487912428Z 15-Feb-2021 09:22:31.487 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler [“http-nio-80”]
2021-02-15T09:22:31.546035449Z 15-Feb-2021 09:22:31.545 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
2021-02-15T09:22:31.678773392Z 15-Feb-2021 09:22:31.678 INFO [main] org.apache.catalina.startup.Catalina.load Initialization processed in 3825 ms
2021-02-15T09:22:31.905138951Z 15-Feb-2021 09:22:31.904 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service [Catalina]
2021-02-15T09:22:31.906207190Z 15-Feb-2021 09:22:31.905 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet Engine: Apache Tomcat/8.5.53
2021-02-15T09:22:32.003529940Z 15-Feb-2021 09:22:31.996 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deploying web application archive [/usr/local/tomcat/webapps/geoserver.war]
2021-02-15T09:30:58.236308317Z 15-Feb-2021 09:30:58.235 INFO [localhost-startStop-1] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
2021-02-15T09:32:06.398834026Z 15-Feb-2021 09:32:06.398 WARNING [localhost-startStop-1] org.geoserver.platform.GeoServerExtensions.checkContext Extension lookup ‘XStreamPersisterInitializer’, but ApplicationContext is unset.
2021-02-15T09:32:06.400586482Z 15-Feb-2021 09:32:06.400 WARNING [localhost-startStop-1] org.geoserver.platform.GeoServerExtensions.checkContext Extension lookup ‘ExtensionFilter’, but ApplicationContext is unset.
2021-02-15T09:32:06.436977148Z 15-Feb-2021 09:32:06.436 WARNING [localhost-startStop-1] org.geoserver.platform.GeoServerExtensions.checkContext Extension lookup ‘ExtensionProvider’, but ApplicationContext is unset.
2021-02-15T09:32:06.439574131Z 15-Feb-2021 09:32:06.439 WARNING [localhost-startStop-1] org.geoserver.platform.GeoServerExtensions.checkContext Extension lookup ‘ExtensionFilter’, but ApplicationContext is unset.
2021-02-15T09:32:07.009092878Z 15 Feb 09:32:06 ERROR [geoserver.logging] - Could not configure log4j overrides
2021-02-15T09:32:07.009129579Z com.thoughtworks.xstream.io.StreamException:
2021-02-15T09:32:07.009135879Z at com.thoughtworks.xstream.io.xml.XppReader.pullNextEvent(XppReader.java:126)
2021-02-15T09:32:07.009140579Z at com.thoughtworks.xstream.io.xml.AbstractPullReader.readRealEvent(AbstractPullReader.java:148)
2021-02-15T09:32:07.009144679Z at com.thoughtworks.xstream.io.xml.AbstractPullReader.readEvent(AbstractPullReader.java:141)
2021-02-15T09:32:07.009157280Z at com.thoughtworks.xstream.io.xml.AbstractPullReader.move(AbstractPullReader.java:118)
2021-02-15T09:32:07.009161980Z at com.thoughtworks.xstream.io.xml.AbstractPullReader.moveDown(AbstractPullReader.java:103)
2021-02-15T09:32:07.009176880Z at com.thoughtworks.xstream.io.xml.XppReader.(XppReader.java:63)
2021-02-15T09:32:07.009180980Z at com.thoughtworks.xstream.io.xml.AbstractXppDriver.createReader(AbstractXppDriver.java:54)
2021-02-15T09:32:07.009184781Z at com.thoughtworks.xstream.io.xml.AbstractXppDriver.createReader(AbstractXppDriver.java:65)
2021-02-15T09:32:07.009188281Z at com.thoughtworks.xstream.XStream.fromXML(XStream.java:1347)
2021-02-15T09:32:07.009191781Z at org.geoserver.config.util.XStreamPersister.load(XStreamPersister.java:665)
2021-02-15T09:32:07.009195181Z at org.geoserver.logging.LoggingStartupContextListener.getLogging(LoggingStartupContextListener.java:118)
2021-02-15T09:32:07.009198781Z at org.geoserver.logging.LoggingStartupContextListener.contextInitialized(LoggingStartupContextListener.java:69)
2021-02-15T09:32:07.009202281Z at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4701)
2021-02-15T09:32:07.009220982Z at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5167)
2021-02-15T09:32:07.009224582Z at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:183)
2021-02-15T09:32:07.009240882Z at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:743)
2021-02-15T09:32:07.009244282Z at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:719)
2021-02-15T09:32:07.009247683Z at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:705)
2021-02-15T09:32:07.009263183Z at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:970)
2021-02-15T09:32:07.009266483Z at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1841)
2021-02-15T09:32:07.009269783Z at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
2021-02-15T09:32:07.009273083Z at java.util.concurrent.FutureTask.run(FutureTask.java:266)
2021-02-15T09:32:07.009277183Z at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
2021-02-15T09:32:07.009280684Z at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
2021-02-15T09:32:07.009283984Z at java.lang.Thread.run(Thread.java:748)
2021-02-15T09:32:07.009287184Z Caused by: java.io.EOFException: input contained no data
2021-02-15T09:32:07.009290384Z at org.xmlpull.mxp1.MXParser.fillBuf(MXParser.java:2983)
2021-02-15T09:32:07.009293684Z at org.xmlpull.mxp1.MXParser.more(MXParser.java:3026)
2021-02-15T09:32:07.009296884Z at org.xmlpull.mxp1.MXParser.parseProlog(MXParser.java:1410)
2021-02-15T09:32:07.009300084Z at org.xmlpull.mxp1.MXParser.nextImpl(MXParser.java:1395)
2021-02-15T09:32:07.009303384Z at org.xmlpull.mxp1.MXParser.next(MXParser.java:1093)
2021-02-15T09:32:07.009306584Z at com.thoughtworks.xstream.io.xml.XppReader.pullNextEvent(XppReader.java:109)
2021-02-15T09:32:07.009313185Z … 24 more
Can anyone guide me in the right direction?
(P.S.: I’ve sent this question before, but from the wrong, unsubscribed, mail address. Apologies if it appears twice.)
Thanks in advance,
Met vriendelijke groet | Kind regards
Jelmer Baas
