[Geoserver-users] S3 Storage with Geoserver
Hello guys,
is it possible to connect geoserver to a S3 storage? I found a plugin documentation but no plugin for download. Is this extension gone? Also, what exactly is the "S3 Support for GeoTiff"-Plugin for? Do I need this if I connect my geoserver to S3 storage?
Kind regards
Andreas
This plugin allows user to use S3 to store the geotiffs and then use the S3 url as a store for raster layer in Geoserver
Thank you,
Krishna G. Lodha
http://krishnaglodha.com
On 3 Mar 2021, 9:05 PM +0530, Andreas Böhme <andreas.boehme@anonymised.com>, wrote:
Hello guys,
Kind regards
Andreas
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
- Earning your support instead of buying it, but Ian Turton: Earning Your Support Instead of Buying it
- The GeoServer user list posting guidelines: User group posting guidelines
If you want to request a feature or an improvement, also see this: Successfully requesting and integrating new features and improvements in GeoServer · geoserver/geoserver Wiki · GitHub
geoserver-users List Signup and Options
Dear Andreas,
you need to try the COG plugin which has just been released.
This for the moment is a community plugin so it is not part of standard releases which means you need to install it from nightly builds.
Before it becomes an official extension we need more users to test this extension so your feedback would be highly appreciated.
Simone Giannecchini
Visit http://bit.ly/gs-services for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
To add some flavor regarding cloud optimized GeoTIFF Andreas, by structuring geotiffs with tiling and providing overviews within the tiff, and with the addition of a tooling environment around it, COGs provide the backbone for very simple but powerful HTTP GET range requests.
I’m glad to see this coming to GeoServer. It means I can easily point my GeoServer instance at the same data that I generate in OpenDroneMap. That simplifies my architecture a lot.
http://sig.cmparks.net/cmp-ms-90x122.pngStephen V. Mather
GIS Manager
(216) 635-3243 (Work)
From: Simone Giannecchini simone.giannecchini@anonymised.com
Sent: Wednesday, March 3, 2021 2:22 PM
To: Andreas Böhme andreas.boehme@anonymised.com
Cc: geoserver-users geoserver-users@lists.sourceforge.net
Subject: Re: [Geoserver-users] S3 Storage with Geoserver
WARNING: This email originated outside of Cleveland Metroparks. DO NOT CLICK links or attachments unless you recognize the sender and know the content is safe.
Dear Andreas,
Simone Giannecchini
@simogeo
Founder/Director
On Wed, Mar 3, 2021 at 4:36 PM Andreas Böhme <andreas.boehme@anonymised.com> wrote:
Hello guys,
what exactly is the “S3 Support for GeoTiff”-Plugin for? Do I need this
Kind regards
Andreas
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Grazie Simone,
I will try and share my experience/problems here with the community.
All the best
Andreas
Am 03.03.2021 um 20:22 schrieb Simone Giannecchini:
Dear Andreas,
Simone Giannecchini
@simogeo
Founder/Director
Hello guys,
Kind regards
Andreas
Geoserver-users@anonymised.coms.sourceforge.net
Andreas Böhme
Techniker/Technician
Landschaftsökologie/Computational Landscape Ecology
Helmholtz-Zentrum für Umweltforschung GmbH - UFZ
Helmholtz Centre for Environmental Research GmbH - UFZ
Permoserstraße 15, 04318 Leipzig, Germany
Phone +49 341 235 1058
[andreas.boehme@anonymised.com](mailto:andreas.boehme@anonymised.com...), [www.ufz.de](http://www.ufz.de)
Sitz der Gesellschaft/Registered Office: Leipzig
Registergericht/Registration Office: Amtsgericht Leipzig
Handelsregister Nr./Trade Register Nr.: B 4703
Vorsitzender des Aufsichtsrats/Chairman of the Supervisory Board: N.N.
Wissenschaftlicher Geschäftsführer/Scientific Managing Director:
Prof. Dr. Georg Teutsch
Administrative Geschäftsführerin/Administrative Managing Director:
Dr. Sabine König
Vermeiden Sie unnötige Ausdrucke./Think before printing.
Informationen aus der Wissenschaft (z.B. Veranstaltungshinweise, Projektangaben, Publikationen,
Bücher)
