[Geoserver-users] S63, S57, S52
Hello,
Do Geoserver permits to import and view ENC with this standards, S63, S57
and S52?
I have read that Envitia Geospatial Viewers permits, with Geoserver, to read
ENC Maps.
Do you confirm it to me?
Thankyou very much
Basilio
View this message in context: http://osgeo-org.1560.x6.nabble.com/S63-S57-S52-tp5323339.html
gdal provides s57 support (http://www.gdal.org/drv_s57.html) but it’s not enabled by default (http://docs.geoserver.org/stable/en/user/data/raster/gdal.html) as for visualisation, you can create any symbol you want, s52-compliant or not, but it’s not in the box. s63 encryption/decryption of enc’s is not available.
You best bet is to contract a party to develop this for you and use un-encrypetd enc’s
2017-06-07 12:49 GMT+02:00 Mistero <basilio.mandas@anonymised.com>:
Hello,
and S52?
ENC Maps.
Thankyou very much
Basilio
Geoserver-users mailing list
Geoserver-users@anonymised.comrge.net
Disclaimer;
This message is just a reflection of what I thought at the time of sending. The message may contain information that is not intended for you or that you don’t understand.
Hello Mark Prince, thank you very much for your advice.
After enabling Gdal where can I find or how can I create s-52 symbols?
How could I decrypt a enc s-63?
Thanks so much.
View this message in context: http://osgeo-org.1560.x6.nabble.com/S63-S57-S52-tp5323339p5326604.html
Have a look at https://www.iho.int/mtg_docs/enc/enc_prod/S-57-FAQ.htm#Q3 to
see ideas as to where to find the symbology of S57
You need a decryption library, for S-63 it is based on blowfish and SHA-1
(see S-63 (encryption standard) - Wikipedia for more
detail) - it is unlikly any opensource project will have the access to
write a dycryptor for this.
Ian
Thanks so much.
Check out the vibrant tech community on one of the world's most
Please make sure you read the following two resources before posting to
this list:
- Earning your support instead of buying it, but Ian Turton:
Earning Your Support Instead of Buying it
- The GeoServer user list posting guidelines: Community - GeoServer
userlist-guidelines.html
geoserver-users List Signup and Options
Ian Turton
Thankyou very much, Ian.
Now I read you link and let me know if it works.
regards
Bas
View this message in context: http://osgeo-org.1560.x6.nabble.com/S63-S57-S52-tp5323339p5326619.html
