[Geoserver-users] Scaling problems creating WMS from raster layer
I am trying to create a WMS which servers a raster layer. The raster
layer is a georeferenced jpg with a world file.
I expected the raster image to be scaled so that when viewed at a
large scale, the whole image is still displayed but just with less
detail. This way the image still lines up with the base map.
Instead what happens is that only a portion of the image is displayed,
the top left corner and then everything only lines up properly when
you zoom to native resolution.
Overall, my goal is to display approximately 1000 raster images on a
map. Perhaps geoserver is not the best way to achieve this. Do I need
to preprocess the images in order to create the different variants to
show at different scales?
Matt
Did you set the projection of the image correctly? That sounds like it would cause that issue.
Ian
On Wed, 29 Aug 2018, 13:53 Matthew Pickering, <matthewtpickering@anonymised.com> wrote:
Matt
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
I tried to at least.
I set the declared CRS to 4326 (which is definitely correct). SRS
handling is the default, "force declared".
The native SRS is EPSG:404000 which I can't change on a per-layer
basis so I assume that's fine.
Is there anything else I should change?
Matt
Ian
Matt
Check out the vibrant tech community on one of the world's most
- Earning your support instead of buying it, but Ian Turton: http://www.ianturton.com/talks/foss4g.html#/
- The GeoServer user list posting guidelines: http://geoserver.org/comm/userlist-guidelines.html
I gave up with geoserver and just used `gdal2tiles` manually. This
means I don't need a server and can just serve the images statically.
Matt
On Wed, Aug 29, 2018 at 12:17 PM Matthew Pickering
Matt
> Ian
>> Matt
>> _______________________________________________
>> Geoserver-users@lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/geoserver-users
I think EPSG:404000 is what it defaults to when it doesn’t understand (or can’t find) the CRS. There’s something it doesn’t like about your world file.
On Thu, Aug 30, 2018 at 7:01 AM, Matthew Pickering <matthewtpickering@anonymised.com> wrote:
I gave up with geoserver and just used gdal2tiles manually. This
means I don’t need a server and can just serve the images statically.
Matt
handling is the default, “force declared”.
The native SRS is EPSG:404000 which I can’t change on a per-layer
basis so I assume that’s fine.
Matt
Ian
Matt
Geoserver-users@anonymised.comsourceforge.net
Geoserver-users@anonymised.com.382…sourceforge.net
Jason Newmoyer
Newmoyer Geospatial Solutions
843.606.0424
jason@anonymised.com
It’s probably the lack of a prj file :slight_smile:
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
