[Geoserver-users] SDE layers projection is shifting
Hi I am a user of Geoserver. I have configured Geo Server with SDE plugin. I
am able to access all my SDE layers. I have successfully published my SDE
layers as well. From layers preview I have generated Google Earth KML file.
There I found an issue that layers projection is slightly shifted with an 50
meters distance.
My spatial reference was pointing to QND95 and EPSG:2932 or wkid is 2932.
For cross checking I have exported my feature classes into shape files and I
exported them POSTGIS Database using command shp2psql. After exporting I
have done the set_Transform command for all the tables that I exported.
I have configured postgresql in Geo Server and was successfully accessing
the postgis table.
That seems to be projecting in a correct way.
I am confused where exactly the problem lies. It should be considered as
major issue.
Any suggestions or help is appreciated.
Prasanth.
View this message in context: http://osgeo-org.1560.x6.nabble.com/SDE-layers-projection-is-shifting-tp5127940.html
Hi Prasanth,
are you doing some reprojection on Geoserver when publishing sde tables?
Can you please check the native srs retrieved from SDE ?
I found this one
http://www.spatialreference.org/ref/epsg/2932/prettywkt/
Also, check that the srs definitions match on Geoserver and PostGis
You can found the srs list under the “demo” page on Geoserver, and the PostGIS one into the “spatial_ref_sys” table
Thank you
Lorenzo Pini
Software Engineer
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK for more information.
Via Poggio alle Viti 1187
On Sun, Mar 9, 2014 at 7:23 PM, mallelaprasanth <mallelaprasanth@anonymised.com> wrote:
meters distance.
the postgis table.
major issue.
Prasanth.
Subversion Kills Productivity. Get off Subversion & Make the Move to Perforce.
With Perforce, you get hassle-free workflows. Merge that actually works.
Faster operations. Version large binaries. Built-in WAN optimization and the
freedom to use Git, Perforce or both. Make the move to Perforce.
http://pubads.g.doubleclick.net/gampad/clk?id=122218951&iu=/4140/ostg.clktrk
Geoserver-users mailing list
