[Geoserver-users] Securing WMTS service
Hi there,
Is there a way to secure the WMTS service in GeoServer that is not listed in the security service dropdown?
Not sure I understand, it is subject to the same security restrictions as any other layer (indeed this was a security issue to ensure this was the case some years ago).
You can set up filter chains using the URL pattern of the geoserver/gwc/ if you wish to impose more restrictions.
Jody Garnett
I believe you want to turn on the “Data security” option in the “caching defaults” page:
https://docs.geoserver.org/main/en/user/geowebcache/config.html#geoserver-data-security
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
