[Geoserver-users] Seeking instruction to resolve vulnerabilities in geoserver application
Dear all,
We are hosted Geoserver (2.9.0 version) application in our office to accomplish the GIS activities.Before to hosted this software in our data center this software should be audit for vulnerabilities.
The security assessment of application found some of the vulnerabilities.Hereby I attached some of the vulnerabilities details for your reference.
Kindly look into the attachment and kindly instruct us to fixing the vulnerabilities.
Details of software used:-
Geoserver-Version 2.9.0
Java version:- JDK1.8.0_121
Apache Tomcat:-apache-tomcat-8.0.41
Web Services created:- WMS and WFS
vulnerability details are attached with description and impact of that vulnerability and also the solution to resolve.So it is request to instruct to resolve issue
Thanks & Regards,
Sharath Shetty
M: 7259590267
Brute force attack vulnerability.pdf (115 KB)
Clickjacking vulnerability.pdf (168 KB)
autocomplete and remember password field enabled.pdf (241 KB)
improper error handling and version disclosure.pdf (231 KB)
session fixation.pdf (126 KB)
First off, GeoServer has a “responsible disclosure” policy that your mail violates in a most severe way:
https://osgeo-org.atlassian.net/projects/GEOS/summary
About the issues:
On Sat, Mar 25, 2017 at 12:29 PM, Sharath Shetty <sharath@anonymised.com> wrote:
Dear all,
Thanks & Regards,
Sharath Shetty
M: 7259590267
Geoserver-users mailing list
Geoserver-users@anonymised.com.382…sourceforge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Hi Andrea,
“The other three have to do with the UI, the common practice is to not expose the user interface to the web, using a proxy and only allowing service paths (geoserver/ows, geoserver/wms, geoserver/wfs for example) to be called from outside, while allowing only access to the UI from specific IPs.”
I have to respectfully but strongly disagree here. I’d certainly say that’s good practice, but it’s not common practice.
To confirm my hypothesis, I just scraped about 650 different /geoserver/web pages scattered across the internet and I received over five hundred (500) responses that had a 200 response code. So I’d suggest that anything that effects the user interface should certainly be considered a security bug and treated accordingly.
Alas, relying on users/admins to do things properly is always a recipe for disaster when it comes to security.
Jonathan
---- On Sat, 25 Mar 2017 15:35:23 +0000 Andrea Aime <andrea.aime@anonymised.com7…> wrote ----
About the issues:
Dear all,
Thanks & Regards,
Sharath Shetty
M: 7259590267
Ing. Andrea Aime
@geowolf
Technical Lead
engaging tech sites, Slashdot.org! http://sdm.link/slashdot_______________________________________________
On Tue, Mar 28, 2017 at 7:59 PM, Jonathan Moules <
jonathan-lists@anonymised.com> wrote:
Hi Andrea,
"The other three have to do with the UI, the common practice is to not
IPs."
I have to respectfully but strongly disagree here. I'd certainly say
that's *good* practice, but it's *not* common practice.
It is common in security conscious setups (military and the like). But yes,
those are indeed not common.
hundred (500) responses that had a 200 response code. So I'd suggest that
Do not worry, we are doing that, you just don't see any discussion about it
because it's security related (and there is no funding attached, so fixes
won't happen overnight).
GeoSolutions Enterprise Support Services for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
