Brendan Graham ha scritto:
I just started this project with a clean installation of 1.5.1. By the way the solution that I posted previoulsy DOES NOT WORK EITHER. The Service still starts and then stops immediately. The logs are attached.
Hmmm. From what I can see:
STATUS | wrapper | 2007/06/08 09:47:55 | Launching a JVM...
FATAL | wrapper | 2007/06/08 09:47:55 | Unable to execute Java command. The system cannot find the file specified. (0x2)
FATAL | wrapper | 2007/06/08 09:47:55 | "%JAVA_HOME%\bin\java" -Djetty.home=../.. -Xms3m -Xmx64m -Djava.library.path="lib" -classpath "lib/wrapper.jar;../start.jar" -Dwrapper.key="FWrjVCSXXsir_0Me" -Dwrapper.port=32000 -Dwrapper.use_system_time="TRUE" -Dwrapper.version="3.1.2" -Dwrapper.native_library="wrapper" -Dwrapper.service="TRUE" -Dwrapper.cpu.timeout="10" -Dwrapper.jvmid=1 org.tanukisoftware.wrapper.WrapperSimpleApp org.mortbay.start.Main
it's not finding the JAVA_HOME system variable. It's either not set,
or not available when the system starts... not sure what to do
about it thought.
Well I have the JAVA_HOME env var set as a User var not a System var. I might try setting it as a Sytem var. I’ll try that and let you know the result.
uSys Integral
Brendan Graham, CTO
e-mail: info@anonymised.com
Tel# 305-793-3778
To: info@anonymised.com
CC: geoserver-users@lists.sourceforge.net
Subject: Re: Service for 1.5.1 won’t start under Vista or XP SP2
Date: Fri, 08 Jun 2007 17:23:21 +0200
MIME-Version: 1.0
Received: from usysinc.com ([66.49.195.114]) by bay0-mc10-f22.bay0.hotmail.com with Microsoft SMTPSVC(6.0.3790.2668); Fri, 8 Jun 2007 08:23:27 -0700
Received: from newhost93.newhost93-server.com (root@anonymised.com)by usysinc.com (8.12.10/8.12.10) with ESMTP id l58FNRvG030918for info@anonymised.com; Fri, 8 Jun 2007 11:23:27 -0400
Received: from plasma.openplans.org (64.90.184.65.static.nyinternet.net [64.90.184.65])by newhost93.newhost93-server.com (8.12.10/8.12.10) with ESMTP id l58FNQO9030913for info@anonymised.com; Fri, 8 Jun 2007 11:23:26 -0400
Received: from [192.168.1.100] (host99-147.pool8248.interbusiness.it [82.48.147.99])(using TLSv1 with cipher DHE-RSA-AES256-SHA (256/256 bits))(No client certificate requested)by plasma.openplans.org (Postfix) with ESMTP id 0E77518D620;Fri, 8 Jun 2007 11:23:25 -0400 (EDT)
attached.
STATUS | wrapper | 2007/06/08 09:47:55 | Launching a JVM…
FATAL | wrapper | 2007/06/08 09:47:55 | “%JAVA_HOME%\bin\java” -Djetty.home=…/… -Xms3m -Xmx64m -Djava.library.path=“lib” -classpath “lib/wrapper.jar;…/start.jar” -Dwrapper.key=“FWrjVCSXXsir_0Me” -Dwrapper.port=32000 -Dwrapper.use_system_time=“TRUE” -Dwrapper.version=“3.1.2” -Dwrapper.native_library=“wrapper” -Dwrapper.service=“TRUE” -Dwrapper.cpu.timeout=“10” -Dwrapper.jvmid=1 org.tanukisoftware.wrapper.WrapperSimpleApp org.mortbay.start.Main
it’s not finding the JAVA_HOME system variable. It’s either not set,
or not available when the system starts… not sure what to do
about it thought.
Dont miss your chance to WIN $10,000 and other great prizes from Microsoft Office Live
