[Geoserver-users] ServiceException - could not find layer
My GeoServer 2.1 installation is serving up wms layers from a postgis 1.4 store, the trouble is that I keep getting pink tiles when pulling the layers to a website using openlayers.
The error report is as below:
Could not find layer geoserver:schools
The above layer is obviously present since the layer preview works fine, GeoServer logs:
2012-10-20 11:01:07,578 INFO [geoserver.wms] -
Request: getServiceInfo
2012-10-20 11:01:07,579 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Could not find layer geoserver:schools
at org.geoserver.wms.map.GetMapKvpRequestReader.parseLayers(GetMapKvpRequestReader.java:1180)
at org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:204)
at org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:74)
at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1230)
at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:488)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:231)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:23)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:394)
at org.springframework.security.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:109)
at org.springframework.security.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:406)
at org.springframework.security.wrapper.SecurityContextHolderAwareRequestFilter.doFilterHttp(SecurityContextHolderAwareRequestFilter.java:91)
at org.springframework.security.ui.SpringSecurityFilter.doFilter(SpringSecurityFilter.java:53)
at org.springframework.security.ui.ExceptionTranslationFilter.doFilterHttp(ExceptionTranslationFilter.java:101)
at org.geonode.security.GeoNodeAnonymousProcessingFilter.doFilter(GeoNodeAnonymousProcessingFilter.java:93)
at org.springframework.security.ui.basicauth.BasicProcessingFilter.doFilterHttp(BasicProcessingFilter.java:174)
at org.geonode.security.GeoNodeCookieProcessingFilter.doFilter(GeoNodeCookieProcessingFilter.java:107)
at org.springframework.security.context.HttpSessionContextIntegrationFilter.doFilterHttp(HttpSessionContextIntegrationFilter.java:235)
at org.springframework.security.util.FilterChainProxy.doFilter(FilterChainProxy.java:185)
at org.springframework.security.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:99)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:71)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:859)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:588)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
at java.lang.Thread.run(Thread.java:636)
while the postgresql.log shows:
2012-10-20 11:32:46 UTC ERROR: relation “public.gt_pk_metadata” does not exist at character 15
2012-10-20 11:32:46 UTC STATEMENT: SELECT * FROM public.GT_PK_METADATA
Has anyone encountered similar errors and how did you solve them ?
Thanks.
Allan Oware
Upande LTD | www.upande.com
Do you have a primary key defined on your layers?
I think that error is it trying to find an alternate primary key. You can define that table if you’re using views (that can’t have a primary key). But if you’re just serving normal layers then defining a primary key should work best.
Also PostGIS 1.4 is 3+ years old at this point, you may have better luck with a more recent version.
On Sat, Oct 20, 2012 at 7:58 AM, Allan Oware <lumtegis@anonymised.com> wrote:
Thanks.
Allan Oware
Everyone hates slow websites. So do we.
Make your web apps faster with AppDynamics
Download AppDynamics Lite for free today:
http://p.sf.net/sfu/appdyn_sfd2d_oct
Geoserver-users mailing list
Hi Chris,
I used shp2pgsql to import the layer shapefile to the database, hence primary key is defined for the layer table as implicit index and implicit sequence are created.
Thanks for the tip, i’ll try to find out what’s wrong with the table/data since that’s where the errors crop up.
On Sat, Oct 20, 2012 at 4:57 PM, Chris Holmes <cholmes@anonymised.com> wrote:
Thanks.
Allan Oware
Allan Oware
Huh. Yeah, shp2pgsql should make it all properly.
Other layers imported the same way work fine? It’s just that layer that messes up?
Does serving the shapefile by itself from GeoServer work?
On Sat, Oct 20, 2012 at 11:01 AM, Allan Oware <lumtegis@anonymised.com> wrote:
Hi Chris,
On Sat, Oct 20, 2012 at 7:58 AM, Allan Oware <lumtegis@anonymised.com4…> wrote:
Thanks.
Allan Oware
Allan Oware
Is there a way to assign a Workspace to a Group Layer using the REST API. I am using Curl and I can create a group layer with no issues but the group layer gets a blank workspace. I would like to assign a workspace to it. Any ideas?
Otto Krauth
Otto Krauth
On Sat, Oct 20, 2012 at 11:38 PM, Otto Krauth <okrauth@anonymised.com> wrote:
You are using GeoServer 2.2.0 right? Only the 2.2.x series has per workspace layer groups as far as I remember.
To see how the configuration for a group in a workspace look like, make one using the GUI and get it via REST
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thanks Andrea,
I will change the version to gs 2.2.x and try.
Otto Krauth
Ing. Andrea Aime
@geowolf
Technical Lead
I am using GS 2.2.0 and when assigning (using REST) an EPSG code to layer (that originally didn’t have one) the change occurs but the resulting layer shows the alert icon and no available.
Is this a known issue?
Thanks
Otto Krauth
