There will be an important GeoServer drop this upcoming Tuesday where we do a simultaneous releases of GeoServer 2.25.2 and 2.24.4 - and ask folks to update promptly.
I trust if you are responsible for a GeoServer instance you managed to update in the last two weeks.
The details vulnerabilities mentioned are now available:
CVE-2024-36401: Remote Code Execution (RCE) vulnerability in evaluating property name expressions
CVE-2024-34696: GeoServer’s Server Status shows sensitive environmental variables and Java properties
CVE-2024-24749: Classpath resource disclosure in GWC Web Resource API on Windows / Tomcat
I am not going to go over the details in email, one of the goals of using CVE system to avoid duplicated or outdated information. So you always have a single point of truth where you can check on the status.
As we are relatively new to using the CVE system to broadcast vulnerabilities I am curious how it is working for you? It is quite complicated to indicate the version range / version patch information to correctly show up for automated scans. If your infrastructure does use automated scans please let me know if scan was able to detect a vulnerable version.
A lot of folks put work into GeoServer each month, and this kind of troubleshooting takes some effort to resolve and communicate. If you are a public institution or service provider using GeoServer instance please consider volunteering on the geoserver-security list.
We would also really appreciate more participation around testing the release candidates each march / September.
These activities are where we as a community share effort, and manage risk, as a team - so it is not so expensive to put out updates each month.
Thanks to Steve Ikeoka, David Blasby and Andrea for working on fixes/mitigations. I can also acknolwege Peter and myself for getting release out promptly. This has been a good team effort.
And thank you for patching yourself over the last week (and if you have not done so already you best hustle…).
Sorry, to avoid further confusion a short update. Ik see some reference to other CVE’s then I was referring to. Maybe caused by me.
But my prime question was that I found a reference stating that for NCSC-2024-0274 there where fixes released for 2.25, 2.24, 2.23, 2.21. Version 2.22 was missing in this list and if there was a reason for that or that we could use the fixes o versie 2.21 als on 2.22.
When a new vulnerability is known and a fix is merged, commercial support providers have the time to
contact their clients, advise that a patch is needed (without further details), and perform a timely delivery for it.
In the case of GeoSolutions, we enumerated all clients, found the ones that were not in a position to upgrade
to an official release right away, and prepared a hotfix for their specific version.
As the public announcement went out, we took the occasion to share the hot fixes with the rest of the community as well.
