[Geoserver-users] Setting Legend Options DPI with Raster
Hey everyone,
I’ve already posted this once, trying again to see if anyone has an answer. Is this the best place to post a question like this?
I’m having an issue with the legend image for my heat map layers not displaying correctly when I specify a DPI through the LEGEND_OPTIONS.
My request:
http://transbasesf.org/geoserver/transbase_v1/ows?TRANSPARENT=TRUE&VIEWPARAMS=timed%3AA&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetLegendGraphic&EXCEPTIONS=application%2Fvnd.ogc.se_xml&LAYER=vw_geoserver_switrs_col_time&STYLE=Heatmap&FORMAT=image%2Fpng&LEGEND_OPTIONS=fontName%3AGill%20Sans%20MT%3BfontSize%3A8%3Bdpi%3A660%3BfontAntiAliasing%3Atrue%3B"
Geoserver’s response:
java.lang.IllegalStateException: It is not legal to have a RasterSymbolizer here
If I remove DPI from my LEGEND_OPTIONS request Geoserver returns the correct legend icon.
Is this a bug or is it just not possible to specify a DPI with a raster layer?
Devan
Devan Morris
E: devan.morris@anonymised.com
Hi Devan,
can you please send us the full stack trace from the Geoserver log?
Mauro
2014-05-12 21:07 GMT+02:00 Morris, Devan (DPH) <Devan.Morris@anonymised.com>:
Hey everyone,
My request:
http://transbasesf.org/geoserver/transbase_v1/ows?TRANSPARENT=TRUE&VIEWPARAMS=timed%3AA&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetLegendGraphic&EXCEPTIONS=application%2Fvnd.ogc.se_xml&LAYER=vw_geoserver_switrs_col_time&STYLE=Heatmap&FORMAT=image%2Fpng&LEGEND_OPTIONS=fontName%3AGill%20Sans%20MT%3BfontSize%3A8%3Bdpi%3A660%3BfontAntiAliasing%3Atrue%3B%22
Devan
Devan Morris
“Accelerate Dev Cycles with Automated Cross-Browser Testing - For FREE
Instantly run your Selenium tests across 300+ browser/OS combos.
Get unparalleled scalability from the best Selenium testing platform available
Simple to use. Nothing to install. Get started now for free.”
http://p.sf.net/sfu/SauceLabs
Geoserver-users mailing list
This is the message I have in the log.
2014-05-14 10:17:08,899 INFO [geoserver.wms] -
Request: getServiceInfo
2014-05-14 10:17:09,523 INFO [geoserver.wms] -
Request: getMap
Time =
Filter = null
Buffer = 0
Format = image/png8
Filters = null
SRS = EPSG:900913
Height = 861
Width = 717
Tiled = false
Palette = null
FeatureVersion = null
Styles = [StyleImpl[ name=Heatmap], StyleImpl[ name=Stacker]]
Layers = [org.geoserver.wms.MapLayerInfo@…6541…, org.geoserver.wms.MapLayerInfo@…6541…]
MaxFeatures = null
Crs = PROJCS[“WGS84 / Google Mercator”,
GEOGCS[“WGS 84”,
DATUM[“World Geodetic System 1984”,
SPHEROID[“WGS 84”, 6378137.0, 298.257223563, AUTHORITY[“EPSG”,“7030”]],
AUTHORITY[“EPSG”,“6326”]],
PRIMEM[“Greenwich”, 0.0, AUTHORITY[“EPSG”,“8901”]],
UNIT[“degree”, 0.017453292519943295],
AXIS[“Longitude”, EAST],
AXIS[“Latitude”, NORTH],
AUTHORITY[“EPSG”,“4326”]],
PROJECTION[“Mercator_1SP”],
PARAMETER[“semi_minor”, 6378137.0],
PARAMETER[“latitude_of_origin”, 0.0],
PARAMETER[“central_meridian”, 0.0],
PARAMETER[“scale_factor”, 1.0],
PARAMETER[“false_easting”, 0.0],
PARAMETER[“false_northing”, 0.0],
UNIT[“m”, 1.0],
AXIS[“x”, EAST],
AXIS[“y”, NORTH],
AUTHORITY[“EPSG”,“900913”]]
Bbox = ReferencedEnvelope[-1.3628036998260634E7 : -1.3624798725541366E7, 4546825.733687567 : 4550714.068606834]
Env = {}
Angle = 0.0
CQLFilter = null
Elevation =
FeatureId = null
StartIndex = null
ViewParams = [{TIMED=A}, {TIMED=A}]
RemoteOwsType = null
RemoteOwsURL = null
FormatOptions = {DPI=96}
BgColor = java.awt.Color[r=255,g=255,b=255]
Transparent = true
SldBody = null
Sld = null
SldVersion = null
ValidateSchema = false
TilesOrigin = null
Exceptions = SE_XML
Version = 1.1.1
Request = GetMap
Get = true
RawKvp = {BBOX=-1.3628036998260634E7,4546825.733687567,-1.3624798725541366E7,4550714.068606834, MAP_RESOLUTION=96, SERVICE=WMS, HEIGHT=861, REQUEST=GetMap, STYLES=Heatmap,Stacker, WIDTH=717, TRANSPARENT=true, VERSION=1.1.1, FORMAT=image/png8, FORMAT_OPTIONS=dpi:96, VIEWPARAMS=timed:A, LAYERS=transbase_v1:vw_geoserver_switrs_col_time,transbase_v1:vw_geoserver_switrs_col_time, SRS=EPSG:900913}
BaseUrl = http://transbasesf.org:80/geoserver/
RequestCharset = UTF-8
2014-05-14 10:17:09,804 INFO [geoserver.wms] -
2014-05-14 10:17:09,804 ERROR [geoserver.ows] -
at org.geoserver.wms.legendgraphic.BufferedImageLegendGraphicBuilder.buildLegendGraphic(BufferedImageLegendGraphicBuilder.java:363)
at org.geoserver.wms.legendgraphic.PNGLegendOutputFormat.produceLegendGraphic(PNGLegendOutputFormat.java:40)
at org.geoserver.wms.legendgraphic.PNGLegendOutputFormat.produceLegendGraphic(PNGLegendOutputFormat.java:21)
at org.geoserver.wms.GetLegendGraphic.run(GetLegendGraphic.java:48)
at org.geoserver.wms.DefaultWebMapService.getLegendGraphic(DefaultWebMapService.java:357)
at sun.reflect.GeneratedMethodAccessor257.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:319)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
at org.geoserver.kml.WebMapServiceKmlInterceptor.invoke(WebMapServiceKmlInterceptor.java:34)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:54)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
at com.sun.proxy.$Proxy65.getLegendGraphic(Unknown Source)
at sun.reflect.GeneratedMethodAccessor242.invoke(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:774)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:272)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:621)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:728)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:27)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:82)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:134)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:48)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:43)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:222)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:502)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:99)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:953)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1023)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:589)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:312)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Hi Devan,
Mauro
2014-05-12 21:07 GMT+02:00 Morris, Devan (DPH) <Devan.Morris@…6494…>:
Hey everyone,
My request:
Devan
Devan Morris
E: devan.morris@…6494…
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK
for more information.
Dott. Mauro Bartolomeoli
@mauro_bart
Senior Software Engineer
Via Poggio alle Viti 1187
