I had a problem downloading a shapefile with the nightly from 6/9.
So I used last night’s and I got another problem which went away when I revered to using a gt-arcsde-2.5-SNAPSHOT.jar that Gabriel gave me on 6/11.
So I think maybe last night’s gt-arcsde-2.5-SNAPSHOT.jar has a problem.
When I used it I got an error message for every vector featureType:
2009-06-19 12:18:30,872 WARN [geoserver.catalog] - Ignoring feature type: ‘AFREEMAN.AUDUBON_GRID_POLY’, error occured loading schema: AFRE
EMAN.AUDUBON_GRID_POLY does not exist
2009-06-19 12:18:30,872 INFO [geoserver.catalog] -
org.geotools.data.DataSourceException: AFREEMAN.AUDUBON_GRID_POLY does not exist
at org.geotools.arcsde.data.FeatureTypeInfoCache.getCachedTypeInfo(FeatureTypeInfoCache.java:269)
at org.geotools.arcsde.data.FeatureTypeInfoCache.getFeatureTypeInfo(FeatureTypeInfoCache.java:206)
at org.geotools.arcsde.data.ArcSDEDataStore.getSchema(ArcSDEDataStore.java:186)
at org.geoserver.catalog.util.LegacyCatalogImporter.readFeatureType(LegacyCatalogImporter.java:503)
at org.geoserver.catalog.util.LegacyCatalogImporter.imprt(LegacyCatalogImporter.java:173)
at org.geoserver.config.GeoServerLoader.initialize(GeoServerLoader.java:119)
at org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(GeoServerLoader.java:81)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(Abstra
ctAutowireCapableBeanFactory.java:350)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.
java:1330)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.ja
va:473)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
at java.security.AccessController.doPrivileged(Native Method)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java
:380)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:221)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:
at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:495)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:162)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFac
tory.java:925)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFact
ory.java:835)
va:440)
:380)
The shapefile problem is still there, with last night’s GeoServer + last night’s SDE plugin except the older gt-arcsde-2.5-SNAPSHOT.jar
2009-06-19 12:40:37,912 INFO [geoserver.wfs] -
Request: getFeature
handle = null
service = wfs
version = 1.0.0
baseUrl = http://maps.massgis.state.ma.us:80/geoserver/
providedVersion = 1.0.0
query = [net.opengis.wfs.impl.QueryTypeImpl@anonymised.com (group: null, propertyName: null, function: null, filter: null, sortBy: null, featureVersion: null, handle: null, srsName: null, typeName: [{http://massgis.state.ma.us/featuretype}GISDATA.TOWNS_POLY])]
maxFeatures = null
outputFormat = SHAPE-ZIP
resultType = results
traverseXlinkDepth = null
traverseXlinkExpiry = null
formatOptions = {}
2009-06-19 12:40:37,912 WARN [data.shapefile] - FieldName FIPS_COUNTY is longer than 10 characters, truncating to FIPS_COUNT
2009-06-19 12:40:37,952 ERROR [data.shapefile] - The following locker still has a lock� read on file:/home/afreeman/apps/apache-tomcat-5.5.26/temp/wfsshptemp0.6462004266500585/GISDATA.TOWNS_POLY.shp by org.geotools.data.shapefile.shp.ShapefileReader
it was created with the following stack trace
org.geotools.data.shapefile.ShpFilesLocker$Trace: Locking file:/home/afreeman/apps/apache-tomcat-5.5.26/temp/wfsshptemp0.6462004266500585/GISDATA.TOWNS_POLY.shp for read by org.geotools.data.shapefile.shp.ShapefileReader in thread TP-Processor1
at org.geotools.data.shapefile.ShpFilesLocker.setTraceException(ShpFilesLocker.java:54)
at org.geotools.data.shapefile.ShpFilesLocker.(ShpFilesLocker.java:33)
at org.geotools.data.shapefile.ShpFiles.acquireRead(ShpFiles.java:365)
at org.geotools.data.shapefile.ShpFiles.getReadChannel(ShpFiles.java:813)
at org.geotools.data.shapefile.shp.ShapefileReader.(ShapefileReader.java:157)
at org.geotools.data.shapefile.ShapefileDataStore.openShapeReader(ShapefileDataStore.java:425)
at org.geotools.data.shapefile.ShapefileDataStore.getAttributesReader(ShapefileDataStore.java:411)
at org.geotools.data.shapefile.ShapefileDataStore.createFeatureWriter(ShapefileDataStore.java:572)
at org.geotools.data.AbstractDataStore.getFeatureWriter(AbstractDataStore.java:486)
at org.geotools.data.AbstractDataStore.getFeatureWriter(AbstractDataStore.java:520)
at org.geotools.data.AbstractDataStore.getFeatureWriterAppend(AbstractDataStore.java:529)
at org.geotools.data.AbstractFeatureStore.addFeatures(AbstractFeatureStore.java:254)
at org.geoserver.wfs.response.ShapeZipOutputFormat.writeCollectionToShapefile(ShapeZipOutputFormat.java:199)
at org.geoserver.wfs.response.ShapeZipOutputFormat.write(ShapeZipOutputFormat.java:157)
at org.geoserver.wfs.WFSGetFeatureOutputFormat.write(WFSGetFeatureOutputFormat.java:137)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:712)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:216)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:269)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:188)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:215)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:124)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:174)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:163)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:174)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:117)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:108)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:174)
at org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyoteHandler.java:200)
at org.apache.jk.common.HandlerRequest.invoke(HandlerRequest.java:283)
at org.apache.jk.common.ChannelSocket.invoke(ChannelSocket.java:773)
at org.apache.jk.common.ChannelSocket.processConnection(ChannelSocket.java:703)
at org.apache.jk.common.ChannelSocket$SocketConnection.runIt(ChannelSocket.java:895)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:689)
at java.lang.Thread.run(Thread.java:595)
2009-06-19 12:40:37,952 ERROR [data.shapefile] - The following locker still has a lock� read on file:/home/afreeman/apps/apache-tomcat-5.5.26/temp/wfsshptemp0.6462004266500585/GISDATA.TOWNS_POLY.dbf by org.geotools.data.shapefile.dbf.DbaseFileReader
org.geotools.data.shapefile.ShpFilesLocker$Trace: Locking file:/home/afreeman/apps/apache-tomcat-5.5.26/temp/wfsshptemp0.6462004266500585/GISDATA.TOWNS_POLY.dbf for read by org.geotools.data.shapefile.dbf.DbaseFileReader in thread TP-Processor1
at org.geotools.data.shapefile.dbf.DbaseFileReader.(DbaseFileReader.java:130)
at org.geotools.data.shapefile.ShapefileDataStore.openDbfReader(ShapefileDataStore.java:450)
2009-06-19 12:40:37,952 ERROR [geoserver.ows] -
java.lang.NullPointerException
at org.geotools.data.shapefile.ShapefileFeatureWriter.write(ShapefileFeatureWriter.java:356)
at org.geotools.data.shapefile.ShapefileFeatureWriter.close(ShapefileFeatureWriter.java:221)
at org.geotools.data.InProcessLockingManager$1.close(InProcessLockingManager.java:348)
at org.geotools.data.AbstractFeatureStore.addFeatures(AbstractFeatureStore.java:276)
